Thread: RTU insulation
08-29-2011, 08:46 PM #1
- Jan 2003
- Kansas City
- 1,476
RTU insulation
I have multiple Carrier RTU's I maintain and the insulation is coming off the inside doors and panels throughout the machines. I can re-insulate these panels, but I was wondering if this was common with Carrier.
08-29-2011, 08:54 PM #2
- Jul 2011
- central Alabama
- 23
Most definitely it is common with Carrier RTU's from what I've seen.
08-29-2011, 09:37 PM #3
- Jul 2010
- So-Cal
- 536
Yea it's common just carry a can of spray glue with you.
08-30-2011, 05:51 PM #4
- Feb 2004
- New Mexico
- 4,684
Stick pins and spray glue. Common problem.
12-04-2011, 10:45 PM #5
- Dec 2011
- 17
Something that I like to do is ask the installers to hand over their leftover “gum tape” , and I use it to apply it around the perimeter of each of the panels that I always see falling off. If you clean the surface good enough, the gum tape seems to hang on a lot longer than the spray glue I used to us.
Just trying to follow that old saying….. “Always leave it better than you found it”
12-05-2011, 02:22 PM #6
- Sep 2006
- Ohio
- 347
This is a common problem with not only Carrier, but Trane and York as well. A lot of the problem is when someone opens a panel with the blower running, this will pull the insulation off.
