Results 14 to 16 of 16
    Thanks again for the replies!!!
    You have me thinking, as I said my original plans were for radiant heat throughout and I could go with baseboards instead of infloor (which at this point would be "under floor") for the carpeted and hardwood areas.
    I guess what really swayed me away from all radiant was A/C, here is a link to my website with pictures of the home under construction http://www.rtol.net/scornell/newhome.htm
    I have plenty of room in the attic for an air handler, any suggestions on the proper way to cool this home if I do go all radiant?
    Not sure what you mean by proper way to cool.
    Do you mean zoned?
    Are your interior walls all done? If you want a zoned AC system you have do the ductwork first before walls are done to bring duct work down to 1st flr and basement. Else 2 AC systems will be needed.
    You seem to have a big investment in radiant already, and should look to get a high efficency modulating and condensing boiler. If your house is well insulated, put extra baseboard in so you can run the whole system at a lower temp. Get a reverse indirect WH like ErgoMax, Turbomax that can also act as a buffer tank for your heating system.
