Results 1 to 13 of 15
    Aug 2011
    Need help reading tempstar info
    MODEL #NTC5075BFD1 I think this is the model for the furnace what does this mean? Btu's heat pump?
    Aug 2010
    Memphis
    Believe 75,000 BTUH. Should have 3 burers in it.
    Aug 2011
    Quote Originally Posted by basshound71 View Post
    Thank you for the info can you tell if its a heat pump from those numbers?
    Aug 2010
    Memphis
    Not from the indoor unit
    Aug 2011
    Got the coil numbers. mod: exm36f1981 serial:l971867754 what I am looking for is the tonage which I am pretty sure is 3 ton and the seer rating? Thanks for your help.
    Virginia
    Quote Originally Posted by ADUBOIS1 View Post
    mod: exm36f1981 what I am looking for is the tonage which I am pretty sure is 3 ton and the seer rating?
    It is a 3 ton unit.
    Coils do not have a seer rating.
    Get the model number of the outdoor unit and I can tell you if it is a heat pump or straight A/C, and what it's seer rating is.
    Apr 2001
    Camel City, NC
    cooling coil
    Be safe not fast. body parts don't grow back
    Aug 2011
    Quote Originally Posted by rundawg View Post
    It is a 3 ton unit.
    Will do thanks for the info.
    Aug 2011
    Quote Originally Posted by selfemployed View Post
    Thank you.
    Apr 2001
    Camel City, NC
    gas furnace
    Can't find the furnace model Ident. guide so here goes.
    Furnace manufactured by Inter-City Products. Sold under names, Arcoaire, Heil and Tempstar.
    NTC denotes upflow or horizontal installation.
    50 indicates 78>80% efficient.
    75 is 75,000 btuh input
    B is furnace width 15 1/2"
    F is 1/3hp. motor with a 10"x8" blower wheel. 1200 cfm or 3 ton cooling capacity.
    Apr 2001
    Camel City, NC
    venting materials
    I should say these furnaces were approved for venting with thermo-plastic pipe at one time. But do to problems with the pipe they should only be vented with B-vent (double wall ) metal piping. If vented horiztonal the venting materials are the same but an approved power venter kit must be use.
    Apr 2001
    Camel City, NC
    Correction -BF is 15 1/2" width & 1/3hp with 10"x8" blower wheel. They are not seprated designations.
    Aug 2011
    I just bought the home I did notice it has white pvc pipe used to vent it. Should I change this out to be safer for my family?
