    Aug 2011
    Need help reading tempstar info
    Just bought a new home and opened up the unit downstairs. The tag says tempstar. I know how to read the serial number L970751855 which means made in 1997 7th week of the year. I need help to find out what size and sear the coil is so I can match up the outside condensor unit as the outside unit was stolen. The model number is NTC5075BFD1. It has gas supply running to the heater also. If anyone can help me It would be greatly appreciated.
    Aug 2011
    Ontario
    Your contractor of choice should be able to figure that out when he prices you on a new o s unit. There is no way to get coil info from furnace model # Replacing coil at this time would be the way to go.
    Aug 2011
    How do I get the model number for the coil? Open up the top of the unit? It is a stacked unit with the blower motor on bottom the furnace in the middle and the coil at the top.
    Jan 2006
    Near Atlanta, GA.
    This is a new member welcome area, not a place to ask questions. That is noted in the header.
    Please post your question in the AOP or Tech to Tech ares.
    Mod
    Thread closed
