Results 1 to 13 of 14
    Oct 2009
    Eastern Washington
    Carrier shuts off in heat.
    Our 3 year old unit has a new compressor as of 2010. Yesterday, the compressor and fan shut off in heat of the day. I turned sprayed with water until it started again.
    Is this simply a 'thermocouple' switch that might need replacing?
    Doug
    Nov 2010
    N. Idaho
    Quote Originally Posted by osage View Post
    Doug
    Thermocouple? In a condenser? nope.
    What part of E. Washington?
    Oct 2009
    Eastern Washington
    Wenatchee
    Oct 2009
    Eastern Washington
    Nov 2010
    N. Idaho
    Model #?
    Any pressure switches? (high pressure)
    Southeastern Pa
    Since the condensing unit was replaced three years ago, what kind of maintenance has been performed on the system?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Nov 2010
    N. Idaho
    Couple other ideas, but not something I can tell a homeowner to do/check.
    Oct 2009
    Eastern Washington
    Quote Originally Posted by Damien View Post
    Model #?
    Carrier #38TKB
    Don't know if it has a high pressure
    Oct 2009
    Eastern Washington
    Quote Originally Posted by timebuilder View Post
    The compressor was replaced a year half ago. No maintenance to the AC since
    Oct 2009
    Eastern Washington
    Model #?
    Model 38TKB. not sure about pressure switches
    Nov 2010
    N. Idaho
    Well, I suppose it may have a high pressure switch as part of an accessory. But with out being there, I dont know.
    Southeastern Pa
    I would start with having the contractor come by and do the yearly preventive maintenance.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Saint Joseph, MI
    Hmmm.... 3 year old unit. Needed a compressor when it was only 1-1/2 year old, now that compressor is shutting down on most likely a limit switch.
    I can't help but think you have other issues going on. Maybe low airflow, incorrect charge. Heck even the condensor fan could be running backwards or something crazy.
    Is the company the repalced the compressor the same one that did the original installation?
    Let us know what the contractor says the problem is with as much detail as possible.
