    I recently purchased a new condo with FAU/AC. The FAU is in the ceiling area and when the thermostat mode is set to "heat", only mildy warm air comes from the vents. Takes approximately 1 hour to gradually increase from 68 to 71 or 72. Is this ok/normal? Thanks!
    If its a heat pump, then yes recovering several degrees, especially in cooler weather requires some time, they are better of maintaining a temp. If its electric heat, then maybe one or more of the elements are open.
    Really we dont have enough information. Outdoor temp?, heat pump? and any other information might help.
    I think he is probably talking about a furdown unit probaby a bad limit or bad heat strip or sequencer there known for those three problems at least here in texas.
