    Phoenix AZ
    carrier heat pump
    hey everone
    i have been working on this carrier unit for some time .....its not cooling of course....its a 50hjq016 we have replace comp # two last month its works fine .....comp number 2 is the one giving us trouble....i replace the two check valves on the evap side of it and i have high super heat and high sub cooling .....unit is only giving out a 10 deg delta t .....need help
    Dec 2009
    Fort Worth, Texas
    high subcooling means overcharge, that with high superheat means restriction.
    check your txv and driers.
    Phoenix AZ
    did the drier when i opened the system and weighed in the charge......i was thinking i have a restriction in the evap coil???????
    Aug 2011
    Los Angeles, CA
    Easiest way to find a restriction in the eval is to kill the I.F.M. and run the compressor. If the eval is restricted you wont get uniform icing on the distributors
    Phoenix AZ
    thanks guys ....i will see what it does on monday morning and post the results ...
