Results 1 to 8 of 8
    WI
    Hmm
    I have a high efficiency furnace installed in 1988. I have noticed that there are times that it will also 'blow' for about 5-10 seconds when it is still at the temp required.
    Does this explain it well...hope so
    What do you guys think?
    Thanks in advance for your timely response!
    SE Michigan
    Unhappy
    Not sure what your saying..sorry.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    WI
    set to 69
    Kicks in at 67 to heat to 69 - so far so good
    sometimes app. 5 minutes after turning off furnace will 'only' try to blow heat for whatever reason for 5-10 seconds.
    This started recently...cannot be good, correct?
    leland nc
    time to have it service
    more then likely the fan limit is picking up residual heat from the heat exchanger and needs to be ajusted.
    it is in your best interest to have it service and set up for the best operation posible
    WI
    Strange - it was cleaned and tuned last season
    that's why you have it done annually.
    good luck
    burlington county n.j.
    is that the last time air filter was replaced?????
