Results 14 to 20 of 20
Thread: cheat sheet?
    Cincinnati, Oh
    Quote Originally Posted by 21degrees View Post
    my point is dont rely too much on factory charge, as far as weighing a charge in to get it close, yes that is alright. but checking SC and SH is mandatory how do you know if the systems is working right. I usely charge a systems with no scale.
    Sounds about what I do.
    Goodman units aren't shipped with 15ft anyways.
    Their shipped for somewhere between 20ft and 100ft lineset. There's no method to it, other than the shorter the lineset, the more overcharged it is.
    Any dry unit, I can weigh in on the money.
    "Just get it done son."
    Dad adjusted
    Quote Originally Posted by 1adam12 View Post
    nor is he in compliance with EPA for not keeping refrigerant records. just sayin...
    Reread the section on record keeping. Don't need to keep records.
    Jun 2011
    Hammond,La.
    Quote Originally Posted by texas2golfer View Post
    I don't always use a scale to weigh in ref. I also know that I have recovered ref from a factory sealed unit and it was no where near what the data plate said factory charge was. I do use my scale after each job and write on the tank the weight in permanent marker. I keep a notebook that I log each call into to keep up with ref used.
    I usually keep the scales going during a recharge. I like to see how much refrigerant is going in so I know the total weight vs what the factory charge +/- line set length comes to. I guess I feel it helps me understand when something may not be right if I start getting very close to what should be in there but the readings don't jive because of a component weakness or failure. Maybe with a few more years of experience I won't be doing it this way.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Apr 2008
    Alberta Canada
    Quote Originally Posted by Rcb2875 View Post
    Without a doubt I agree on dialing in a system with SH/SC is the proper way to go but I was addressing the long line set situation and or dry system and recharge.
    How do you know how much to charge a customer for refrigerant if you don't weigh out what you are putting in? Just curious if you use a flat fee per tonnage or some other method?
    Nice looking wrap on the van btw.
    I do use scale for service, we charge $ pernce ounze. I was thinking you guys were talking about new installs. Thanks for the comments
    Do it right the first time.
    Apr 2008
    Alberta Canada
    We are not in the states and the EPA is a big joke! they are just fronts for big business!!
    Apr 2011
    Coastal Maine
    There is a stock formula that has to do with the capacity of the pipe sizes.
    For example, if you take the length of the liquid line say 3/8" and multiply it by .037 (or something like that) it will give you the liquid volume of that line. Same for 1/4". Length times 0.015 (not exact but you get the idea).
    I used to have it committed to memory, but all the manufacturers now have that info in the install manual and most of the Japanese manufacturers put the charging info on the service cover at the condenser. Right under the schematic.
    These are just rules of thumb. Take a moment and read the charging info with the condenser, they all seem to have the multipliers in there now.
    Jun 2011
    Hammond,La.
    I would say they are fronts for big government since they are moving big business out of country and killing small business. Them being a big joke we can agree on. But that is probably best for ARP section.
