Results 1 to 13 of 20
Thread: cheat sheet?
    Aug 2011
    MPLS, MN
    cheat sheet?
    anyone know of a cheat sheet for charging a new reidental a/c unit with 410a. i know the condensor comes with about 10-15 feet of chage in the unit but im dealing with a 30 to almost 40 foot line set. and i heard of a cheat sheet for weight to lenght , seeing if i can same an hour of pissing it in and checking.
    Nov 2010
    N. Idaho
    I think our installers go .6 oz. per foot after 15ft
    The install manual has the instructions for how much additional charge to add.
    Apr 2011
    West of DFW
    Use the installation book, it comes handy with useful info. I do have to say, Goodman use to lack a lot of info., but now there better.
    Apr 2009
    San Diego
    you can get close to correct charge by adding 3 oz for every 5 feet after the first 15 feet. After that use manufacturers target subcool to dial it in within 3 degrees of target for TXV system.
    Jun 2011
    Hammond,La.
    all I remember seeing is the 0.6oz per foot over 15' on residential units I have worked with that use a 3/8 liquid line. Have seen some older stuff use a 1/4" liquid line that I am sure would be less than 0.6oz per additional foot.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Apr 2008
    Alberta Canada
    yah as long as unit has the right amount from factory. Weighing refrigerant is alright but learn how to used SC/SH.
    Do it right the first time.
    Jun 2011
    Hammond,La.
    Quote Originally Posted by 21degrees View Post
    I like to weigh in to get close to the target charge on long line sets. Loading to factory weights for the 15' and then throttling in on the vapor side the rest of the way can take forever sometimes.
    Apr 2008
    Alberta Canada
    my point is dont rely too much on factory charge, as far as weighing a charge in to get it close, yes that is alright. but checking SC and SH is mandatory how do you know if the systems is working right. I usely charge a systems with no scale.
    Jun 2011
    Hammond,La.
    Without a doubt I agree on dialing in a system with SH/SC is the proper way to go but I was addressing the long line set situation and or dry system and recharge.
    How do you know how much to charge a customer for refrigerant if you don't weigh out what you are putting in? Just curious if you use a flat fee per tonnage or some other method?
    Nice looking wrap on the van btw.
    Aug 2011
    ky
    nor is he in compliance with EPA for not keeping refrigerant records. just sayin...
    Quote Originally Posted by Rcb2875 View Post
    Nov 2010
    N. Idaho
    My boss also said he never charged systems by weight, nor on service calls. Thats what I asked him, how would you know what to charge for price?
    Weigh factory in and then fine tune with SH/SC
    Plus in this field, WE NEED FACTS
    I don't always use a scale to weigh in ref. I also know that I have recovered ref from a factory sealed unit and it was no where near what the data plate said factory charge was. I do use my scale after each job and write on the tank the weight in permanent marker. I keep a notebook that I log each call into to keep up with ref used.
