Results 1 to 10 of 10
Thread: carrier
    Aug 2011
    houston, texas
    carrier
    i have a carrier 3 ton air handler in my attic and cant figure out how to clean the coil. there is no access what so ever. the coil is actually in the air handler. i think its a 3 year old system.
    Sep 2009
    S.C.
    Normally we take the coil outside and pressure wash it.
    And if this is "Tech to Tech", why are HO's here? (Home Owners)
    And for the 1,000,000 time... Look at the "Tech to Tech Chat", See Something In RED Like... NO AOP OR DIY>>
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    Aug 2011
    houston, texas
    wow ...lots of work... i was hoping to stick a can of coil cleaner in there and spray. then hose down with water hose.
    Grottoes VA
    You are going to spray down a coil in an attic with a water hose?
    Jun 2011
    Hammond,La.
    Quote Originally Posted by el_coyote2373 View Post
    Speechless... really I am. Good luck with that.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Jan 2006
    Indiana
    Shoot a video of that please so I can show to the techs. I'll put it in the what not to do section or homeowners that spend more trying to save a buck lol.
    Mar 2011
    Galveston Texas
    first off if your having to clean a 3yo coil then you have worse problems then needing to clean a coil. If everything is done properly with the R/A sealed properly and the HO changes the filter on a regular basis a coil shouldn't have to be cleaned.
    Aug 2011
    Goose Creek ,SC
    Quote Originally Posted by cuchulain View Post
    Not to step on the proverbial toe , but even in an ideal dust free enviroment with a nice PROPERLY sealed return and regular filter changes with those nice high dollar dust and allergan filters. A yearly to bi-annually application of self rinsing coil cleaner and inspection of the air handling unit by a technician with credentials is still highly recommended. To top it I have heard that some companies give the extended 10 year warranties contingent upon the H/O keeping a service agreement preferably with them,and they will not honor the warranty if the agreement is not kept. Besides who doesnt recommend to clean an evaporator/indoor coil ?
    May 2011
    Ripley, WV
    Quote Originally Posted by PalmettoMaintPro View Post
    Do you believe that on a clean coil simply applying self rinsing coil cleaner will be sufficient to maintain a clean coil? I don't get to use it often and was curious if it's really that good, because if it is, it seems like a good time saver on those bi-annual maintenance agreements.
    Aug 2011
    Goose Creek ,SC
    Lightbulb
    Not all self rinsing cleaner are the same . The ones that are a brighter green in color seem to work a little better as far as clinging to the coil . The clingy is what I look for ,that is what emulsifies the dirt to really get it out. I use it almost full strength so it leaves an actual "I just got my coil cleaned " smell which is ok and safe for the H/O. I also get the one that is USDA approved for use in meat packing plant or whatever the bottle says. Remember though , this stuff will keep a clean coil clean .If you got one that has grown stuff I would go foamy cleaner which is hard to work with indoors and dangerous ,or I would pull it and wash it garden hose style with foamy cleaner in an outdoor enviroment. But to answer your question ,yes the self rinsing stuff is a great time saver. I use it on all my already properly clean coils. IF you think about it you could spray it on a heat pump in winter and the defrost cycle would rinse it .Or at least I think it would
