Results 1 to 9 of 9
Thread: rla/lra
    Aug 2011
    houston, texas
    rla/lra
    whats the differance in these two? i know they are run load amps and load run amps but there is a big differance in the numbers. my understanding is that rla is the amps being drawn while running but what is lra?
    Oct 2010
    SW Michigan, near Battle Creek
    Locked Rotor Amps. what the thing draws with no rotation-no back emf. untill the thermal safy trips or something melts wich ever comes first.
    Aug 2011
    houston, texas
    ok. that makes since. i dont know why a tech. told me they were called load run amps.
    Nov 2008
    Bristol Va.
    Quote Originally Posted by el_coyote2373 View Post
    becouse he DID NOT KNKOW what it meant either.
    dogboy
    Jul 2011
    central Alabama
    I thought rla was rated load amps....just an engineer's estimation of what a motor will pull under normal load.
    Oct 2010
    there is a rated amps listed that is the motor working full-out
    Tallahassee, FL
    If im drawing anthing close to full on RLA ....im looking for reasons why.
    Dec 2009
    maroon lazyboy
    On a lennox (and probably others)
    rated load amps are the amps drawn during design conditions.
    Which is high OAT and high indoor load
    at least that's what I was told.
    Virginia
    Quote Originally Posted by knave View Post
    Usually under normal conditions a compressor is going to pull about 75-80% of whats listed as RLA. At least thats what I've seen over the years.
    When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
