    Nov 2008
    DFW,TX
    Coil placement feedback; upstream vs downstream issues?
    Ok so i typically do not do many modular blower installs but have come accross afew and reading the instructions for this particualr brand it states the evaporator coil must be downstream of the blower, basically before the blower after the return. I understand we have no choice on fan coil thats the way they are built and may have something to do with water overflowing into heat strips and components, also understand same concept with upflow/vertical installs for same reason..
    However a horizontal install IMO we should have a choice and i feel we should , like a furnace install, put the coils in the upstream before the supply plenum for same reasons . I think cold air leads to moisture which also helps stick dirt and debris onto blower motor/wheel/electronics and that cannot be good.
    Why can the coil NOT be put in supply side of modular blower. Ive seem many installs way back done that way..
    so whats the theory behind the new install instructions stating to NOT install them that way now? can the blower motors not push as hard as they can pull?
    is this only for some brands?
    feedback?
    Straight cool, go for it. Keeps the mold out of the blower. Can't do it with a HP that has backup.
    Jun 2011
    Hammond,La.
    Good question. I have never put much thought into it but just assumed that the coils were placed at the return side to keep them from getting blasted with instant heat on electric furnaces. Will have a more gradual temperature change. Not sure what a rapid expansion of refrigerant would do to these light coils going from a winter cold evap to an almost instantly 100 something degrees blast from the heat strips.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Nov 2008
    DFW,TX
    thats what i was thinking , good point though i guess its good to just do them the same way as maybe some of these installs could be upgraded to a HP system at a later date and having the attic equipment installed correctly the first time will save time and money in the future..
    thats good enough for me.. thanks
    Cincinnati, Oh
    Imagine that coil leaking onto your heat strips.
    "Just get it done son."
    Dad adjusted
    Tallahassee, FL
    Also with the blower outlet being smaller - you wouldnt get a very uniform air flow through the coil on the supply side.
    Unless you put a nice transition and had the coil wayyy off the blower outlet. IMO
