    Nov 2005
    Twin Cities, Minnesota
    I am getting a York Pt9 80,000 btuh furnace installed in my house next week (2stage, multi-speed (not variable)). The installer says he will put in a Robert Shaw 9600 programmable digital thermostat. When I went to check it out online I saw the following: "System configurations:
    2 - 5 wire single stage gas, oil, or electric systems"
    Does that mean this is intended for a single stage system, not a 2 stage? I look at the other model #'s like say the 9615 and they say the following: "System configurations:
    Multi-stage gas, oil or electric heating/ cooling syatems (up to two stage heat, two stage cool)"
    Need advice - will this properly operate my 2 stage furnace?
    Thanks.
    Tyler, TX
    I'm not a York dealer, so I don't know specific model numbers.
    However...
    Many furnaces control 2nd stage through an on-board timer, so a single stage thermostat is all that is required.
    Your dealer will know if your furnace requires 2 stage.
    Just ask him.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Unless you want to defeat much of the advantage of 2 stage heat, use a 2 stage stat. Tell the dealer to put a 9615 or other 2 stage stat on.
    Oct 2001
    Waterford Michigan
    It will work but I would opt for the true two-stage thermostat. This may mean your contractor has to make some wiring modifications probably at extra cost.
    Extra Cost ?
    If the contractor failed to disclose the need for additional wiring or new wiring to control a 2 stage tstat at this time I would say he needs to eat it and provide it free of charge.
    True most equi9pment mfg provide a timer to control two stage operation but this is not true two stage control.... The tstat needs to know the setpoint to efficently control 2 stage calls for heat not a dam timer !
    AllTemp Heating & Cooling
    Although that furnace board timer is settable at 10, 15, or 20 minutes, you'll be more comfortable if you have them install a 2 stage stat, after all, your paying for comfort when you get a 2 stage furnace.
    Since he didn't plan on a 2 stage stat, it may cost you alittle more then the original quote for him to do it.
