Thread: Heat Pump Inop.
    Richmond Va.
    Unhappy
    Heat Pump has'nt worked all year. Unit blows air but that's all. Won't Cool or Heat. And it's getting COLD *laff*
    Anyway, I did have it inspected and was told that the Reverse Flow Valve is bad. Cost about $XXXX to fix.
    Any ideas?
    (No pricing, due to site rules )
    [Edited by jultzya on 12-02-2005 at 02:58 PM]
    switch to emergency heat, if you have electric auxilliary, until you decide to repair or replace.
    i would call another contractor and get a second opinion.
    you stated unit will not cool or heat, if thats so then you would have a differant problem than the reversing valve. sound like its low on charge and that could explain why i doesnt cool and with the pressure low it cant change positions so it doesnt heat.
    Florida
    If it won't cool or heat and costs $XXXX to repair, if it is anywhere near 10 years old, replace it.I would get a second opinion though.
    >>>edit... no pricing
    [Edited by jultzya on 12-02-2005 at 02:59 PM]
