Results 14 to 18 of 18
08-30-2011, 08:16 PM #14
- Jul 2011
- central Alabama
- 23
When necessary, I usually will only use piercing valves to recover refrigerant and install permanent access fittings.
08-30-2011, 08:51 PM #15Karst means cave. So, I search for caves.
08-31-2011, 11:54 AM #16
- Dec 2005
- New Hampshire
- 33
You are supposed to use the piercing fitting to pull out the refrigerant. Then you braze on a new process tube and use one of these http://www.sjdiscounttools.com/rob12458.html to attach your hose to the end of the process tube (its like a rubber compression fitting) and charge by weight. Then you pinch off the tube, remove the fitting and braze over the end of the process tube. This way everything is still hermetic when you are done. It's not that hard as long as you make sure the process tube is long enough to work with.
Really though, just braze on a regular access fitting and be done with it.
08-31-2011, 01:05 PM #17
Professional Member*
- Aug 2008
- S. Grand Prairie
- 243
Same here...had a 20+ year old 10 ton Lennox with a defective high pressure switch a couple weeks ago, no core under the bad switch so I just brazed in the new service valve and wired in a new high pressure switch...took longer to go to the parts house than it did to do the work...
Originally Posted by ladyfire3374:
"I used to wake up excited about the challenges of the day. Now the anticipation level is somewhere between a root canal and a colonoscopy."
08-31-2011, 10:13 PM #18Karst means cave. So, I search for caves.
