Results 1 to 9 of 9
Thread: New BluVac LTE
    Jan 2005
    Akron
    New BluVac LTE
    For those of you that are looking at the BluVac, but were looking for a lower cost version, ($179.95) it is soon to be on the shelf at TruTech Tools. We expect delivery of the BluVac LTE the week after next. The LTE version uses the same measurement technology at a 1 micron resolution without the productivity features.
    The AccuTools® BluVac LTE Digital Vacuum Gauge is a state-of-the-art digital vacuum gauge utilizing patent-pending technology to deliver the highest accuracy available.
    Operating for up to 300 hours on a single 9V alkaline battery, the BluVac LTE sports a large 1/2" numeric display and a bright blue backlight. The BluVac measures from 0—25,000 microns with 1 micron resolution.
    Possessing the same accuracy and reliability of the standard BluVac gauge, the LTE is ideal for budget conscious technicians without sacrificing performance.
    Innovative Oil Sensor and Self-Diagnostics ensure accuracy. The BluVac and BluVac LTE are the only field-calibratable vacuum gauges that require no special equipment for calibration.
    What's Included
    Detachable Swivel Hook
    Battery (One 9V Alkaline)
    Instruction Manual
    Features
    0 to 25,000 Micron Range with 1 Micron Resolution
    Measures Vacuum in Microns, Pascals, Millibar, Millitorr and mmHg
    Large, high-visibility back-lit LCD display
    Long Battery Life — Up to 300 Hours on One 9V Alkaline Battery
    “Analog” Vacuum Level Bar Graph
    Automatic Oil Sensor
    Built-in memory retains all previous settings
    Rugged, Compact Design — About the Size of a Manifold Gauge
    Calibration Self Test — Can be field calibrated with no special equipment
    Sensor withstands overpressure up to 500 PSI
    Ideal for HVAC/R Service and Industrial Use
    JLB,
    louisville, ky
    sounds good, might be able to get the bossman to go for a couple of those
    got a side by side chart or link to one for easier comparison?
    Jan 2005
    Akron
    Will work on getting it posted
    JLB,
    Jan 2005
    Akron
    Here it is.
    JLB,
    Mar 2009
    Triad - North Carolina
    Thank You,
    This is insightful.
    Yes, I've seen that before and it doesn't mean I like it.
    Jul 2010
    Andalucia
    Quote Originally Posted by jim bergmann View Post
    " The BluVac and BluVac LTE are the only field-calibratable vacuum gauges that require no special equipment for calibration."
    Aren't the Thermal Engineering micron gauges also field calibrated with no special equipment?
    With Trump it is not like you are losing the presidency, you will be gaining a cable channel.
    If I win I will put Hilary in jail. If I lose, the system is rigged. Trump's banana republic USA 2016.
    Can't wait to see who is the first to say in 2020 we need to nominate a true conservative.
    Irish bookie already paying out on Hillary Clinton victory bets
    http://www.marketwatch.com/story/iri...ets-2016-10-18
    “I’ve said if Ivanka weren’t my daughter, perhaps I’d be dating her.” Donald Trump
    Quote Originally Posted by pageyjim View Post
    Don't know if it's what you call special but this is what you need to field calibrate one from the two page instructions.
    FWIW A second vacuum gauge with know accuracy is on the list.
    THERMAL VAK-CHECK CALIBRATION INSTRUCTIONS
    EQUIPMENT NEEDED:
    �� DIGITAL MULTIMETER WITH 200mA RANGE
    �� TWO D CELL BATTERIES
    �� 47 OHM RESISTOR 1/4W or GREATER
    �� JUMPERLEAD
    �� VACUUM PUMP & VACUUM INDICATOR OF KNOWN ACCURACY
    Calibration should be performed in ambient temperatures of 70°- 90°F
    http://www.thermalengineeringcompany...01,%204575.pdf
    South Carolina
    Here it is.
    thnx Jim
    It is what it is unless I say differently !!!!
