Results 1 to 13 of 27
Thread: Lennox G60V
    Jul 2011
    Lennox G60V
    Hi I just want to know if anyone can tell me how quiet a furnace a Lennox G60V is - like on a scale of 1-10? I would like to buy one not the G61V but the G60V but is it the same motor in these 2 furnaces? My house is about 2100 sq ft - should it be an 070? Sizing wise? Thanks...
    I don't know
    If you're in a cold climate anything below 90% afue should be out of the question.
    G61 is probably quieter because it has a sealed burner compartment.
    Both should be fairly quiet.
    No one on here has seen your house.
    Jul 2011
    Thanks for that amd
    I appreciate your reply - I wanted a B-vent instead of the hi-eff one because it would be easier to install here. I heard good things about the G61V just wanted to know if the G60V was same motor & as quiet. I am in Canada & unfortunately literally no contractors here offer one of those load calculations they all just guesstimate - thanks
    Jul 2011
    OOPS SORRY amd you are in Ontario I should specify I am in Vancouver so maybe they offer the calculation there but not here
    May 2008
    Missouri
    Regardless of ease of installation, I'd also recommend a 92 to 95% furnace. Nothing can make up for the loss of AFUE and increased operating costs in a shorter period of time than a simple upgrade!!
    In a machine room
    Apparently money is no object if you are even considering going with a non condensing furnace in Canada! I could probably count on one hand the number of non condensing furnaces we have installed in the last 2 years.
    The highest attainable efficiency (btu in vs btu out) on that G60 would be about 72% as opposed to 90% on the G61. And that is if they are set up to the best fuel/air mix with a combustion analyzer(not many contractors do).
    That means out of every hundred dollars spent on gas, $28 goes up the chimney on the non condensing.
    And yes the G61 would be quieter.
    Worry is a really gross misuse of one's imagination. -- PHM
    I don't know
    Mid efficiency furnaces are obsolete in Canada - they don't import them any more.
    Vancouver? I would get a cheaper furnace with an ecm blower (such as the gmvc95, icp vs95 or york tm9v) and a heatpump.
    *Air handler with heat strips can be used instead of furnace if there's a 200 amp service.
    Jul 2011
    Thanks all of you & chuckcrj I am in Vancouver not an extreme climate here and just really interested in why the G61v would be quieter than the G60V in your opinion?
    I don't know
    High efficiency furnaces when installed correctly are sealed combustion - less burner and inducer noise.
    With cheap hydro electricity and a mild climate, heating with a furnace is such a waste.
    Jul 2011
    So thanks this is really helpful - sorry I am not sure I understand - even if the G60V 80% eff B vent furnace (which I can buy from one company who has old stock here) & the 95% high eff G61V have the same motor in them - same fan etc - the G61V is quieter?
    Jul 2009
    Ontario, Canada
    I work for a large Lennox company and I've worked on hundreds of G61V and many G60V models. Both are very quiet units and reliable. On the G60v, the burner compartment is open to allow combustion air into the burner. So you will hear the burners running when it's on.
    On the g61v--the burner compartment is sealed in a box reducing noise of the burners during operation--this however, is best achieved when the combustion air intake pipe is piped outdoors.
    Saint Joseph, MI
    If your ductwork is undersized, all system will be noisy, form air velocity at hte registers. If its' sized OK, then the isnulated cabinet of any better VS furnace will be queter than a standard blower. A high efficiency is queiter tha na B-vent. Quite a bit. With quiet ductwork, you'll still hear a B-vent furnace in a closet or basement with most modern construction.
    burlington county n.j.
    Quote Originally Posted by johnt2_2002 View Post
    +1
