Results 1 to 9 of 9
    This morning we lost power. The electric co was able to restore power and everything works fine except the furnace. We have a Heil model ntc-6100 gfg1. we have tried all the switches and obvious but the fan will not come on nor the burner will not light.
    Is there a reset button or something? I checked the thermostat too to no avail.
    We are in MI and it is getting pretty cold in here 52!
    Any and all help/suggestions would be much appreciated.
    Thank you -jen
    Tyler, TX
    No reset.
    Be sure you are getting power to the furnace.
    Be sure the doors are in place.
    If it still won't run, call for service.
    It won't take a technician long to find the problem, and delaying the call will not heat your house.
    Good luck.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    As bwal2 said, call a tech.
    SE Michigan
    Where in MI? If your around metro detroit shoot me an email. Its in my credentials.
    [Edited by coolwhip on 12-01-2005 at 05:28 PM]
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Apr 2003
    Shut the unit off, wait for an hour, turn unit back on.
    If this doesn't fix it, call for service.
    Nov 2001
    east kansas
    Wait an hour? I'd wait a couple of minutes. Why an hour?
    Check your breakers. Then call the service company.
    Beware of advice given by some guy on the Internet.
    Check this
    Depending on your unit there may be an in line fuse inside the furance that smoked when the power was interupted. If your can turn your breaker off to the furance open it up and look sometimes it will look just like a 3 amp car fuse,check that. Then if there is no fuse your transformer may have burned up. You will smell it if it did.
    Apr 2003
    He said no blower or burner... nothing about the inducer not running. So, if the unit was operating at the time the power went off...
    The aux limit on the blower (tripped due to high temp shut off) which is wired in series with the pressure switch, will keep the unit from firing... which doesn't signal the EFT to energize the blower.
    Leaving the unit set, will allow for the 'auto-reset' limit to close and then the unit will operate normally.
    Another way to speed this process is to turn the blower to the 'on' position, which will cool the sensor quicker. But could lead to a 'constant' blower problem, cause the homeowner 'forgets' to switch the fan setting back to auto.
    Nov 2001
    east kansas
    But the power went off in the morning and it was after 4 when the OP posted.
    Well Jen how did you come out?
