Results 14 to 26 of 31
Thread: Trane guys I have a question
08-30-2011, 09:31 PM #14
- Aug 2011
- Los Angeles, CA
- 34
It reconfigures the L.T.B for conventional thermostats. The pain in the neck is to see if your unit is pre 93 or after 93. They change where the wires land on the LTB
08-30-2011, 10:27 PM #15
- Aug 2011
- fayetteville nc
- 18
Ok, ill check. It is a reliatel board. It is cool all the things u can do it just cost to much to replace.
08-30-2011, 11:42 PM #16
- Aug 2011
- Los Angeles, CA
- 34
Yeah. I like working on Trans units. They are usually pretty easy. I hate Yorks, no field experience by anyone in the factory, the electrical panel is way to small.
08-31-2011, 07:22 AM #17
- Aug 2011
- fayetteville nc
- 18
I'm new to commerical. So I have a lot to learn about walkins and econimizers. I don't understand yorks compressor lockouts. Is it only lock if low voltage amp draw is to high to it ? I don't understand how it sence the amps.
08-31-2011, 03:52 PM #18
Professional Member*
- Oct 2007
- Richmond, VA
- 334
08-31-2011, 07:25 PM #19
- Aug 2011
- fayetteville nc
- 18
I can do that if it bothers you
08-31-2011, 07:37 PM #20
- Jul 2007
- The Hot South
- 869
Hello my friend and welcome to the forum!
It's not that it bothers him, but the person who started this thread is looking for help with his Trane unit and when you hijack a thread and change the subject, it takes away from the original person looking for help. Its no big deal, we've all done it (including me).
09-04-2011, 09:20 PM #21
- Aug 2011
- San Jose California
- 85
Instead of the expense of ball valve and shell driers, recover, reinstall the relatively inexpensive factory recommended driers, and recharge?
Our fate is ours alone to decide as long as we remain armed heavily enough to dictate it.
09-05-2011, 08:38 PM #22
Could be:
Dirty coils
Wrong fan blades
Low load
Overcharge
Non-condensibles
Undercharge
Restricted driers
Or any combination of any number of the above.
I hope this is helpful. If it's not, post the following, and maybe I can offer more assistance.
constant volume or vfd? fan speed/static press.?
low ambient dampers?
return temp.
supply temp.
mixed air temp.
outside ambient temp.
suction press.
disch. press.
liquid press.
how many compressors running and which circuits?
how many fans running?
subcooling
superheat (all 3 of them)
press. drop across driers
clear sight glass?Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
09-06-2011, 11:46 PM #23
- Mar 2010
- Va.
- 178
Make sure all of the condenser fans are rotating the right direction. You will bypass a lot of the coil if one of the fans is running backward. There should be a noticeable temperature drop across the drier if it's restricted.
09-18-2011, 01:13 PM #24
Teckster, I don't remember the part # but there is a 5 blade cond. fan that needs to be on your unit due to the low airflow here.
09-18-2011, 04:05 PM #25
- Aug 2011
- 12
If it helps any!
Hello, just thought I'd put my two cents worth if it helps. If both condenser coils are clean and match the unit, make sure that the motors and blades are original and match as well. Now if other people have messed with it, I personally would start from scratch and recover, remove old driers flush system with nitrogen make sure that there are no " Restrictions ", including in the metering device. Pull a good vacuum of 700 microns or lower if possible and charge with virgin refrigerant. After all you don't know what might be in the existing refrigerant. Well hope that helps and don't give up I'm sure you'll figure it out. It sounds like a restriction of some sort. Might be within the system, or circulation of air through the condensers. Check for distinctions or irregularity in the line sizes compare circuits. Good Luck!
09-19-2011, 11:06 PM #26
Now I know who you are just call me when you get back from vacation!!!
