Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 76
    In a machine room
    Quote Originally Posted by amd View Post
    A 2 story house can be cooled properly without zoning, provided that the duct system is well designed and a 2-3F difference is tolerable.
    Cooled yes. Or heated yes. A system can be designed to heat OR (not and) cool a 2 story house.
    A given house needs a lot more cooling on the 2nd floor in summer than it needs heating in the winter due to the fact that hot air rises.
    For best comfort you should always zone floors separately.
    Worry is a really gross misuse of one's imagination. -- PHM
    Jun 2009
    Albuquerque NM
    About now I think the OP is probably wishing he hadn't asked the original question.
    I don't know
    The ductwork can be over-designed on the second floor and dampered down during the heating season. Seasonal balancing is a must.
    In a machine room
    True.
    Jun 2009
    Albuquerque NM
    Seasonal balancing could get a little tricky in the Denver area. They have large temperature swings from day to night like we do here, and it's even possible to require heating at night and cooling in the day. This is one reason I'd recommend a dual-fuel system for that area. For heating, the lower heat pump discharge temperatures and longer run times can give you a nice low, continuous heat and better circulation.
    Jun 2001
    Some climates use a heat pump for upstairs and gas furnace downstairs.
    I don't know
    ^That's probably to avoid dealing with gas in the attic.
    The best option is to not put equipment in the attic though.
  8. Likes darctangent liked this post
  9. #21
    Rochester NY
    Properly sized multi stage equipment running near continuously in a tight, well built home will make all floors comfortable all the time. High and low returns in upstairs rooms will help insure this, make sure you have them. You may also need to close bedroom doors during extreme temperatures.
    Elegant design makes brute force approach unnecessary. If it were my home the one additional thing I'd do is size ductwork 1/2 to 1 ton larger than your 2 ton heat pump.
  10. Likes darctangent liked this post
  11. #22
    Jul 2002
    Yuma, AZ
    • Two ton is probably all the home needs. Undersizing is RARE.
    • Comfort will always be compromised in a 2 story home unless you zone.
    • Two unit zoning is not the best solution. Forget the arguement that if one unit fails, you have another. If that ever happens, a hotel is a better, more economically wise solution.
    • Ducted Zoning on a single system is the way to go. The ductwork should be 25% larger than standard design.
    • Most contractors prefer 2 unit zoning because they do better financially and they don't really understand how to make more complex duct systems work.
    • As usual, the results depend on the contractor, not the manufacturers.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
  12. Likes darctangent liked this post
  13. #23
    SW FL
    EXCELLENT Advice throughout this thread.
    My house would be two 1.5 ton heat pumps.
    SIMPLE and most Reliable.
    How much, if any, would Denver [ mile high city ] "light" air impact selection and performance?
    Designer Dan
  14. #24
    Saint Augustine, Florida, United States
    Around here, production builders are not using anyone other then production installation co.'s that just want to throw that system in. Usually about impossible to get them to do a great duct job. Bypass dampers in backward. Long flex runs with little distribution boxes, almost never ductboard plenumns or any metal duct. Difficult to get changes made to the plans, because all the bidding is done through Prod Builder. The zone systems I see regularly would be ripped apart if I posted pics here.
  15. #25
    Jul 2002
    Yuma, AZ
    Quote Originally Posted by JWB View Post
    SO TRUE. About the only thing that you can count on is that the unit will not be undersized. Production installation companies rely on oversizing to cover thier own sins. Production homes leave comfort out of the equation. The duct system is really the comfort system in the home as the duct design and construction determines the distribution of the cooling and heating air. Show me a real estate contract that defines and guarantees any level of comfort. Maybe, "somewhere over the rainbow"....
    Mark Twain
  16. #26
    Rochester, NY, USA
    Im just going to throw my in here.
    I have done RNC for 20+ years, mostly custom homes from 2200ft² to 7000ft². Did a lot of tract homes to.
    A 2300 ft² home can easily be done with one system. But someone has to do the math to get the proper air flow to the furthest register from the furnace/air handler. The key to most two story homes is the return air from the second floor. If you can get the proper return air you'll be fine. Hi/lo returns are the best, it's what I did in every home. I put individual returns in each room. NEVER-EVER use a central return air...they don't work nearly as well as individual returns. anywhere you can get a double return air (6x30)do it.
    Here's the deal: IF this home is 2x6 construction, with very good windows (low-e ) with above code insulation in the attic a 2 ton should be able to handle this home with no problem.
    I have never had an air flow issue, never even had a "it's drafty" issue.
    so this can be done, but the installing company better know what their doing
    as a side note:In this area (your market maybe different) there is no way your going to get a builder to put two systems in a 2300ft² house unless the buyer demands it, and then the buyer is going to pay through the butt for it I have been doing this a long time, I know how builders think. Thats why I got out of RNC.
    "THE LIONS DON'T CARE ABOUT THE OPINIONS OF THE SHEEP"
    Scott Isreal
    Coward County Sheriff ​
  17. Likes darctangent liked this post
