Results 1 to 9 of 9
    Jun 2011
    Compressor makes loud bang sound
    I am dealing with a Bryant 3 ton 410a split system ac. Customer reported the AC making a loud banging noise on start up. I put my gauges on and started the unit. In the off position the gauges read 175 psi. On start up the suction drops to about 130 and the head runs up to about 275. Then after about 45 seconds the head shoots to 600 the unit makes a loud sound. Then the sound of the compressor changes and it returns to equalization but the compressor is running.
    Whats causing this I realize the compressor is not pumping after the loud sound.
    Houston,Tx.
    Quote Originally Posted by bigwave View Post
    On start up the suction drops to about 130 and the head runs up to about 275. Then after about 45 seconds the head shoots to 600 the unit makes a loud sound..
    Must have a dirty coil, or slow condenser motor, or overcharge, I am about the only Pro here that could even imagine it being a restriction.
    Virginia
    As per the AOP Rules only Professional Members * can reply with
    advice
    to the OP. Anyone may post and ask questions. They may even
    question the * member answer but not give advice or expand on the
    advice given. Please read these rules for a complete understanding. AOP Rules
    For those in our industry who wish to become a Professional Member, please click here and follow the
    instructions. Apply for Professional
    Membership
    Jun 2011
    I thought it may be a restriction. In order for it to shoot up that fast wouldn't it have to be a complete restriction and the suction pressure drop? Why does it run without pumping.
    I don't know
    advice
    Membership
    It could be a restriction, plus 4 pounds of excess charge.
    Jul 2002
    Yuma, AZ
    Internal pressure relief (popoff) valve is built into the compressor. This saves the compressor from abusive conditions. Find the abuse and fix it.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Aug 2011
    McKinney, Texas
    We had the same problem a couple weeks back on a service call with a 5 ton Goodman.
    advice
    Membership
    May 2008
    Missouri
    Bigwave, if you're actually repairing someone's AC, then you need to get the pro status and you can go into technical stuff!
