Results 1 to 2 of 2
    Nov 2005
    I have a Goodman 2 1/2 ton heat pump. The outside unit runs even when the thermostat is not calling for heat.
    I tried resetting the breakers on the inside unit, no luck.
    I also reset the breakers for the outside unit as well, no luck.
    I turned off the thermostat for now.
    Suggestions?
    Leave the breakers off until a tech can check it out. Running without an indoor unit will kill the compressor eventually.
