I need a temporary fix till i get my gas meter installed.
I heard that Diesel and furnace oil are just about the same? Would i be able to use Diesel fuel from a gas station to fill up my furnace's oil tank on a temporary basis?
I want to make 100% sure before attempting this? Its not going to cause a fire/explosion right?
The more confirmations i get, the better...thanks for posting.
# 2 diesel and heating oil are the same, except for the color
paul
Is #2 diesel what i can get at the gas station?
yes its perfectly ok just be sure to use a dedicated can, preferably a blue one to reduce chances of getting anything other than no 2 oil in your tank, gas will kill.
diesel is probably cleaner than the oil ya have been getting, it will just cost you a fortune in road use taxes
be carefull that there is nothing but oil in the can
Yeah, thanks, that would be alright, ill be buying a new can to use...Its just a temporary fix, weather is getting cold and i need heat...just waiting until i get my NG furnace installed.
No problem...they are the same. I've done it numerous times when the %$!!% tank went empty during the first cold spell and I brain-farted and forgot to fill it up.
You can do it
I'm a factory rep for boilers with Becket, Carlin, Wayne, Heat-Wise, and Riello burners mounted on them. These guys are all telling you the right thing.
Road use fuel is cleaner, and won't gel as fast when it gets VERY cold. It has the same BTU content.
It's a different color so the government can tell that the road use tax has or hasn't been paid on it.
Noel
I'm not suggesting that you do it but...
My sister in law ran out of oil one cold night a couple of years ago w/ little kids in the house. I hooked her up to run out of a 5 gallon diesel can instead of out of her tank. She ran that way for a few days until her next paycheck.
Ryan
Maintenance Guy
naysayer, skeptic, conspiracy theorist
I would check to see if you could get some offroad fuel instead. It's the exact same thing as #2, but dyed red and you don't pay road tax's on it. Most big truck stops should have it.
Might save you a few bucks.
Yes you can. Another confirmation.
off road deisel would be the way to go about 20 cents a gallon cheaper here. on the flip side of that i have been running heating oil in a deisel tractor for the last 2 years with no problems. filter just gets dirty a little faster.
why do you want to lose all those btu's by switching to ng? it gonna cost you almost 30% more on ng. at least you're not on lp.
My oil furnace and tank are getting really old, at least 30+ years. Its a very low efficiency, im doing the switch to NG high efficiency furnace when i get the meter installed. I think its about time too, been wanting to do this change for a long time, everyone is on NG, i think im the only one on my street with the oiltanker coming to fill my tank...
- You may not post replies
- You may not edit your posts
Forum Rules
