Results 14 to 23 of 23
    The Hot South
    It could be that the kanooter valve is not set to 90 degrees.
    It could also be the compressor isn't running.
    Rochester NY
    Maybe the halfafalf valve is low on blinker fluid.
    At least that's what the car repair guys tell my fiancé, and that usually fixes it.
    Fort Worth, TX
    The flux capacitor for the compressor blew when the henway went bad.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Dec 2000
    phoenix, arizona
    I think it is the Chinese made adjustable valve need to be replace.
    Decide what you want, decide what you are willing to exchange for it. Establish your priorities and go to work." H.L. Hunt
    "In order that people may be happy in their work, these three things are needed: They must be fit for it. They must not do too much of it. And they must have a sense of success in it." John uskin
    Aug 2011
    THANKS EVERY ONE, BUT IT WAS THE COMPRESSOR. IT WAS REVERSED. THANKS TO THE ONE TO ADVISED THAT.
    New England
    Quote Originally Posted by alpalmerin View Post
    Just turn it around - should be all set
    Feb 2007
    milford ct
    Quote Originally Posted by Shophound View Post
    whats a henway LOL
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
    Dec 2006
    Litchfield,Il
    Please don't yell. What happened when you reversed the leads?
    If your not getting the results you desire then change. People change from either desperation or inspiration.
    Apr 2003
    Columbus Ohio
    well if it was r22 it was about 60 degrees that day
    May 2011
    Houston, Texas
    What is in reversed? The compressor? The gauge? Man I get a headache reading this thread! LOL
