Results 1 to 6 of 6
    sheave replacement
    Seeking help or advice with a sheave replacement job assignment on a York packaged unit M-D1EG090N13046E. The RTU with the drive package on the bottom. I might have to fabricate my one puller if I can't fine one that will fit between the shaft end and the base... any help is appreciated.
    Thanks.
    Jul 2011
    central Alabama
    You may have to pull the blower assembly to access the sheave.
    sheave/pulley job
    That is what I was kinda leaning towards as a last resort...... goona look at small pullers and see exactly how much room I have to work with. May end up substituting the jacking bolt furnished with a shorter one, the shaft extension is only about 1.5". I'd make my own puller but I don't have a welder,saw and 1/2" x 2 CRS... but I just might. Hafta see on Monday.
    Thanks.
    Where ya from in Alabama pion?Montgomery area here.
    Jul 2011
    central Alabama
    B'ham area here
    Mar 2010
    Kent, WA.
    Just pull the blower assembly. no need to wast time and money fiddling around with finding/making a puller. Most of the time the blower assembly is on slides or only 4 screws holding it in.
