Thread: york ycas200
    ohio
    york ycas200
    I have a leak at the discharge end plate of the compressor. Can I remove this to replace the gasket behind the plate or is this not possible without doing damage. It looks like it is just a mater of removing the king valve and unbolting the plate, is this correct or does this hold it all together?
    Not in Iran
    You can do this , get a new gasket., and make sure you clean and prep the new connection., dont forget to isolate the gas lol
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Jul 2011
    Columbus, Ohio
    I here a lot of people call an access valve a king valve. The king valve is any type of valve in the liquid line that isolates the high and low side of the system. It could be a ball valve, globe valve, angle valve any type of valve. But it is the king valve. The valve you are talking about is a Henry angle valve, or dicharge isolation valve.
    Sorry to be a jerk just a little pet peev of mine.
    Aug 2011
    SACRAMENTO
    THANK YOU
    Thank you for that clarification on the isolation valve
