Results 14 to 22 of 22
    Jun 2009
    Jesup GA.
    Read the instructions first!!
    Altmar, New York, United States
    Quote Originally Posted by Cool_Air View Post
    your doing it backwards.
    Mar 2009
    Triad - North Carolina
    Quote Originally Posted by SBKold View Post
    Youre joking right?
    SEEE!
    No I was not kidding. The one that came with the coil is not necessarily the correct one.
    Customer complaint: "The company that installed this system has had to add refrigerant every spring and remove refrigerant each fall. Why is my system behaving this way?"
    Answer: Incorrect installation and setup.
    Recent: A one and a half ton condensing unit does not need 3 tons of air. The coil was mounted on a furnace with a 3 ton blower on high. Original installers replaced 3 TXV's and one compressor in the first year.
    I can't take a picture of stupidity for the wall of shame.
    Yes, I've seen that before and it doesn't mean I like it.
    Urbandale IA. USA
    Youre joking right?
    NO !
    Isn't the one with the evap coil the correct one for that coil?
    I work MOSTLY with straight cooling, not HP.
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Tallahassee, FL
    Quote Originally Posted by cehs View Post
    NO !
    NO! Its a generic R22 piston.
    Usually for the largest size condensor that is a match for that coil.
    Piston size is determined by OD unit size and SEER and refrigerant type.
    Goodman has always supplied a piston chart with most replacement coils.
    Urbandale IA. USA
    Most of what I work on is straight cooling.
    I still have found that the chart shows the piston on the evap SOMETIMES, and SOMETIMES the one on the condenser.
    AGAIN there is USUALLY only 1 number difference....
    Tallahassee, FL
    I usually find them more than one size off myself.
    You may want to get in the habit of using the one off the condensor.
    Its the right way to do it.
    Jul 2002
    Yuma, AZ
    This thread actually turned into something.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Jun 2009
    Jesup GA.
    I understand now
