I recently had a new Climatemaster thermostat installed on my Tranquility 27 HEat Pump. The new thermostat has humidty controls but it does not have a differential setting.
The differential adjustment will vary the number of degrees, from the set point, before a call for heating or cooling is made.
Without this the heat pump is cycling on/off too often in cool and is calling stage 2 in heat mode.
Are there any other settings on this thermostat that can do the same as a differential offset setting.
I believe the thermostat is ATP32U01 or ATP32U02. The manual lists them both.
