Results 14 to 21 of 21
Thread: trane problem
    pa
    Thought i would let you guys know that the liquid line was blocked almost completley shut about 10 inches from condenser. Running like a champ now.
    Jul 2011
    Columbus, Ohio
    Just wondering what was the blockage.
    pa
    Dont know what it was black hard as hell crap.We were thinking compressor windings so we changed out compressor had about 4 inchs of liq line plugged. I felt like a jackass for not seeing the problem. On this unit it has a sensor right before the filter dryer wrapped with insulation when i was checking it out i seen filter freezing so i changed the filter if i would have removed the insulation i would have seen it was freezing about 3 inches before filter right were it was plugged other tech found it in about 30 minutes.
    Apr 2010
    Minnesota
    I had some of that stuff in a 2 ton Trane condensor once, don't know what the heck it is either. That was a couple years ago. Just replaced the condensor coil, kept the compressor. Still running after 2 years.
    Atlanta,GA.
    could it be that when they did the piping that theplugs in the copper were not removed and melted when being brazed?
    pa
    dont know what it was but there was a good bit of it.
    Winston-Salem NC
    Your problem could have been easily solved by installing something other than Trane.
    pa
    yea that building has about 60 units 55 are yorks 5 tranes the last two i worked on were trane . Fixed to leaks on the one in three weeks third time replaced condenser.
