Results 1 to 8 of 8
08-16-2011, 12:41 AM #1
New Guest
- Aug 2011
- Royse City, TX
- 2
Minimum Tonnage Requirements/Laws? Texas...
Curious if there are laws or requirements in place, specifically in the state of Texas, that establish a minimum tonnage requirement based on certain square footages for residential applications?
I have a 2,762 sqft house (8ft ceilings throughout the 2/3rds of the house, 9ft in the remaining 1/3rd) that was built in August of 2005. The builder installed a single 5 ton unit using a damper system to divide that single system into two zones - up and down.
It seems to be underpowered and after talking with friends, I've learned that laws may exist requiring a 2nd unit in my case. If such a law or requirement exists, if you know where I could find the documentation, that would greatly help!
Thanks for any help or suggestions you may have.
Steve
08-16-2011, 12:45 AM #2
- Jun 2006
- Plano,TX
- 10
There are no laws other than following code, being competent and ethical. Performing a manual J heat gain/loss calculation (computerized) along with a manual S will settle all doubts about the proper size
08-16-2011, 01:03 AM #3
banned reincarnate
- Aug 2011
- 568
i've NEVER heard of a law saying how many systems to put in ones house, and i mean never!
08-16-2011, 02:04 AM #4
- Sep 2002
- I don't know
- 2,888
You have a large unit which I would think should do the job.It seems to be underpowered
Might want to get the system checked over - charge, airflow, control wiring, etc.
08-16-2011, 07:23 AM #5
Professional Member*
- Aug 2008
- S. Grand Prairie
- 243
My first suggestion if your concerned would be to call out a local HVAC company to check the system.
There are no laws, as said from others, regarding min/max for sizing, etc. Also, your home should have been inspected to make sure everything was done to code when it was built.
With the heat we've been having this summer, it could just be your unit is doing it's best.Originally Posted by ladyfire3374:
"I used to wake up excited about the challenges of the day. Now the anticipation level is somewhere between a root canal and a colonoscopy."
08-16-2011, 11:23 PM #6
- Jun 2007
- Round Rock
- 2,890
I'm from Texas and do business in Texas. Local jurisidictions might require a manual j for plan and permit approval. There is no way you could ever set a law for this. Otherwise everything would be way oversized. Not sure of where Royce is. But 5 tons on your sq. footage unless you have a glass house with no trees should be plenty. I'm not sure of what you think is "underpowered". I've had one of these in the last 2 years that thinks it needs to be 62 all the time in the house no matter what the temperature outside. You really need to define "underpowered". You should be able to maintain 77ish during the heat of the day which is 108 in Austin lately.
I like DIY'ers. They pay better to fix.
08-16-2011, 11:24 PM #7
New Guest
- Aug 2011
- Royse City, TX
- 2
thanks for the tips and suggestions, guys, i'll call an HVAC company out to check things over and go from there.
08-16-2011, 11:34 PM #8
banned reincarnate
- Aug 2011
- 568
