Results 1 to 13 of 14
    Apr 2011
    Wink yciv leak (funny) but difficult
    hi every body ,
    the welding man (solderer ) want to attach the lader at the body of the chiller but he was not found any body to guied him , he make a hole in the top of the chiller, so the condenser was punctured , now ? from which (good) place I can make welding and how can I open the top cover or what the best procedure to repair the pipe
    im attached the place of the hole
    Puerto Rico
    The best procedure to repair, will be with your local JCI service center. From the YCIV's installation manual, I read that the YCIV's use the top rows of the condenser coil, to cool the VFD's glycol loop. If this glycol loop in the condenser coil piping was perforated, it would have leaked glycol, instead of R123 refrigerant. Which one leaked? Either way, get $10K, and call JCI. Good Luck!
    pennsylvania
    Quote Originally Posted by bobcontrols View Post
    123? I am taking a popular line from the site. "I will not say what I want to"
    pennsylvania
    Quote Originally Posted by MOTASIM View Post
    hi every body ,
    NOPE. not going to do it.
    Somewhere in the world.
    That is R134a no easy fix for that one due to location gotta watch what you screw into.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Apr 2011
    how to ?
    Quote Originally Posted by york56 View Post
    MR YORK56 ,
    CAN I REMOVE THE TOP COVER OR MAKE A SLOT AT THE SIDE OF THE CONDENSER TO WELD THE PIPE ? WHATS THE EASY WAY
    PLEASE URGENT
    THANX ALOT
    Apr 2011
    MR YORK56 ,
    PLEASE URGENT
    THANX ALOT
    I would ID the exact tube thats leaking and I would cut out that row and pinch and braze at each end one row isn't going to hurt that chiller.
    Aug 2009
    Cyprus
    the top rows is the oil cooling and the lower rows is VSD cooling
    Dec 2008
    Dixiana, AL
    MR YORK56 ,
    PLEASE URGENT
    THANX ALOT
    If you know exactly where the leak is but you can't look at the chiller and figure out how to get the panels off to get at the leak and fix it, then you need to get someone there that's familiar with this type equipment and let them do it.
    Will most likely be easy to find look for the oil stain top section is the oil cooler for that circut.
    Apr 2011
    Smile leak ( the same answer)
    Quote Originally Posted by klove View Post
    I KNW THAT ITS AN OIL LOOP BUT I AM ASK ABOUT THE PROCEDURE TO REPAIRE IT BY REMOVE THE TOP COVER ALTHOUGH ITS WELDED HARD OR MAKE ASLOT AT THE SIDE OF THE CONDENSER THATS MY QUESTION AND WHAT THE TYPE OF BRAZE CAN I USE
    THANX EVERYBODY
    Not in Iran
    TAKE UR CAPS LOCK OFF
    STOP YELLING AT US
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
