Results 1 to 13 of 34
    Trane chiller techs
    Gents,
    Why is the rebuild so easy on a trane chiller compared to a york , have trane done a geared drive in recent years , yes. many years ago, 20 thou ho ho
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by rover View Post
    Gents,
    You've obviously become delusional due to the high temperatures this year...
    Either that, or you've not done many, if any rebuilds.
    philadelphia
    Try doing 1500 ton bench grinders although the technical end is easy there is some serious pucker factor when you pull the first stage volute
    Nov 2008
    Gents,
    Would it make you happier if they were harder to rebuild. For the most part I think that you answered your own question. Trane being a direct drive instead of using a transmission.
    Trane has been and does make a gear drive 134 machine for sale outside the USA
    The compressor is similar to the current production Carrier.
    Houston TX
    Trane gear drive
    rover- Yes Trane did make a gear drive centrifugal compressor, however I don't think there are many still left out there. It was CVAA, CVAB and CVAC. All were air cooled chillers with 2 or 3- 8' belt driven fans, a walk in control compartment and the starter was hung on the outside rear of the unit inside a cabinet. It had black box type overload, current and transition timers and was an R-12 system. Tonnage range was 150 - 320 tons. When it was loaded up it was smooth, unloaded it was shake, rattle and roll especially if you were standing inside of it.
    -Geo
    Of all the things I have lost in my life, I miss my mind the most-GEO
    A land down under
    Due to different market drivers outside of North America, including refrigerant phase out dates ahead of the Montreal protocol, the Trane Company produced the aircooled Centravac models CVAD (R12/UCP1) through to CVAE (R134a/UCP2) in the 150-340 ton range until it was eventually replaced by the RTAC product. There are still many of these in operation today particularly in Hong Kong and the Middle East.
    The water cooled gear drive Centravac offering continues today with the water cooled CVGF (AdaptiView/R134a) as the product offering. Again there are many of the previous water cooled gear drive models CVGA through CVGE in operation today but only outside of the US.
    IMHO the directve models are the premium product however the gear drive centrifugals have also proven to be just as reliable.
    Quote Originally Posted by ga1279 View Post
    rover- Yes Trane did make a gear drive centrifugal compressor, however I don't think there are many still left out there....
    i will be collecting vibration data on 2 of them later this week!
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Jan 2012
    Perth Down Under
    Like my name implies I luv gear-drive chillers made by Trane. So much so that I have been working on them for over 30 years. I have seen chiller running for 15 years without a rebuild. Trane built the following water cooled machines on R12:- cvga, and the air cooled cvaa, cvac. It was then sent overseas where Trane in France built the cvga from 340 ton through to 900 tons and today most of these machines have been converted to R134a. Frane continued with this product and brought on line the cvge and cvae machines on R134a only. The cvae was replaced by the rtaa and rtac chillers but the water cooled remained in operation. In the late nineties Lacrosse put on the drawing board a new gear drive chiller optimized for R134a with a falling film evaporator call the cvgf which is in production in Lacrosse and China today. Export only. Sorry
    A land down under
    Quote Originally Posted by Gear-Drive Guru View Post
    GD-Guru, don't forget the CVGB (CCGB compressor) series. I agree the R12 machines were bullet-proof, have opened compressors after 60,000+hrs for conversion to R134a and found the bearings almost as new. IMHO I don't believe the product was as robust once connverted to R134a.
    Attached Files Attached Files
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by Screwit View Post
    So, why don't they sell those things in the States? Also, per the picture, why'd they see fit to leave the motor tail bearing off the larger of the two?
    8th grade
    truer words were never spoken!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by DITAW View Post
    A land down under
    Quote Originally Posted by klove View Post
    The earlier gear drive design was sold in the states as an air cooled package, the later gear drives design were sold in markets under accelerated HCFC phase outs. The direct drive design offers a higher efficiency than the current gear drive design.
    The low speed bearings are a cantilever design located in the low speed bearing housing, I cannot accurately answer the reasoning behind this design. A question for a Guru who was closeley involved with the design phase!
    Dec 2008
    Dixiana, AL
    I know Trane isn't the only one that does that, but it sure seems like a lot of overhung weight....
