Results 1 to 10 of 10
Thread: a/c noise
    Aug 2011
    a/c noise
    I have a Trane XR80-it makes a pretty loud THUMP noise when it first comes on and another loud THUMP noise when it shuts off. Any idea what it might be? The unit has been doing this for a while now.
    Dec 2006
    Litchfield,Il
    Quote Originally Posted by MEBEGRAM View Post
    Meb - How old is the unit? Have you had it serviced lately?
    If your not getting the results you desire then change. People change from either desperation or inspiration.
    Aug 2011
    The unit is 6 yrs. old. It hasn't been serviced for 3 years. Husband said it sounds like a filter flipping back and forth somewhere but there is no filter in the unit downstairs. Just the one in the intake-upstairs. I said it sounds like a gas noise but he said the a/c runs on electricity-not gas like the furnace.
    Dec 2006
    Litchfield,Il
    Check your filter and make sure it doesn't need changed.
    Sounds like your ductwork is poping. (flexing in the middle)
    Aug 2011
    i would try going down stairs by unit when off! then have some one start up a/c stand there and observe! look at return duct going into the side of unit, does it seem to slightly flex in ? do you hear the noise, where does it sound like its coming from. look and listen?then while still in basement have someone turn unit off at t-stat, while someone is in basement observing ! does the return duct move,flex make any noise? where do you hear the noise! the key is eyes,ears,patience, if you still can't narrow it down, call a tech, but basicaly , a tech will use the eyes,ears,then listen and look for the noise! good luck.
    Aug 2011
    Smile
    Quote Originally Posted by MM#7 View Post
    ps follow up, like other guy said, check and make sure filter is very clean, also you can try to start the unit w/o filter in, after doing all the other checks, to see if that quiets noise down, but after the test, make sure to put filter back in unit!
    Virginia
    some furnaces have a filter inside the furnace that should have been removed on install
    Aug 2011
    the filter is new/clean. It gets changed once a month. We can not see any other filters in the unit. Non down by the blower. We don't see the ductwork flexing anywhere. Thanks though.
    Dec 2006
    Litchfield,Il
    Okedoke.....sounds like you need to make the call. You can go on our contractor locator map and see if there is a specialist nearby. If not then your nearest trusted HVAC Co.
    It needs to be inspected a little further. It could be something else that maybe or maybe not damaging your system. Why take a chance. Don't delay.
    Best wishes.
    Aug 2011
    Hmm
    Quote Originally Posted by luskys a/c View Post
    Best wishes.
    SMART POST!
