Results 1 to 10 of 10
    Aug 2005
    I ran out of oil-have some now-how do i get this thing going? its an oldy, American Standard Arco Liner Model WO351, series 4B. When i hit the restart switch it runs a minute but wont fire-up. How do i prime or whatever?
    chicago suburbs
    that's easy..pick up the phone book and call someone.
    FILL OUT YOUR PROFILE!!
    Its too late. when you let it run out, you olso get the sludge from the bottom of the tank. Now the fuel distrbution has been compromised. Call for service tommorrow. Go to Lowes and by 3) 20 $ radiant heaters and then store them in a closet for the next emergency. Emergency add-on will probly cost more than the 3 heaters.
    Aug 2005
    fuel distribution compromised?
    ive run out at least 4 times in 7 years, my previous oil man was able to "prime it" in about a minute, dont know what he did though. my current delivery man doesnt know how.
    recently had furnace worked on and that tech said it was easy, "the bleader valve is right on the side of the furnace" the tank is two years old and was recently drained due to me putting gasoline instead of diesel fuel into it (another story, and where i got my user name).
    anyways i dont think sludge would be an issue (but what do i know). The point is $, i dont got none at the moment,
    i appreciate your professional opinion and would have a tech here if i could.
    low on cash in central mass and its getting cold. i have one little electric heater and cant by two more.
    Can anyone help?
    Apr 2004
    Not here
    [Edited by Lusker on 11-20-2005 at 11:53 AM]
    ...SHEEESH!!!
    Southold, NY
    Dummy
    1) STOP HITTING THAT RESET NOW.
    You let your tank run dry now you have to bite the bullet.
    Learn by this mistake.
    If you can get through the night fine, If not then you’ll have to pay.
    Aug 2005
    its all about liability
    i know, thought maybe a non pro would offer some advice, thanks for the link.
    Since you already admit to putting gas in the tank.
    You now know why we won't tell you how to do it.
    Wait till Monday and have it serviced while the tech's there.
    Money may be tight, but a tune up will save you money.
    Stop trying things yourself, your costing yourself money, not saving.
    Aug 2005
    thanks pecmsg
    i only hit it twice thirty minutes apart, i read what that could cause. Still cant pay though.
    Southold, NY
    Re: thanks pecmsg
    Well at least your learning.
    Unfortunately your going to have to pay for this one. As was stated before when the empty tank was filled is kicked up any sediment that was in there. Your filter should be changed, I would also have the system completely checked out. Money may be tight but the winter just started. Put it on your credit card and in the future don’t let the tank run low. Good Luck.
