Results 1 to 8 of 8
    Aug 2011
    Confused Help identfiy A/C model? Compressor dead!
    I'm trying to help my friend fix his dead compressor in his outdoor A/C unit. I wrote down some of the information. We need to replace the compressor so if anyone has any recommended places they know where I can buy the replacement compressor that would be greatly appreciated. Heres the info-
    model# HBBD-F0485B
    serial# W0N6313873
    the minimum circuit capacity is 30.3
    compressor 208-230V 1pH 60Hz 23 RLA
    unit supply 208-230V 1pH 60Hz 115 LRA
    The year it was bought was probably 2007-2008 (not 100% sure)
    From the address on the label I'm sure its either a YORK, Luxaire, or coleman.
    I don't know
    It's a york 4 ton 13 seer - builder's special.
    Either something killed it (overcharge, insufficient airflow, mismatched coil, wrong metering device, and much more) or it's not dead.
    Aug 2011
    He rents his house and he believes because the filter wasn't changed for 6 months that it over worked and the compressor died. would that be possible?
    Aug 2011
    Quote Originally Posted by Kazimierzk2004 View Post
    any things possible, have you had a hvac guy out there yet? by the way how dirty was the filter?
    Grottoes VA
    2007-2008 would make it still under warranty.
    Aug 2011
    it was very dirty. if it was because of the filter would the warranty cover that?
    Arizona
    Help your friend and call someone that knows what there doing! You will save a lot of $'s
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    chicago suburbs
    Quote Originally Posted by karsthuntr View Post
    BINGO!
    FILL OUT YOUR PROFILE!!
Tags for this Thread
