Results 14 to 24 of 24
Thread: coleman coil
    South Texas
    had one one time installers installed txv didn't take out the flow rater, low suction poor split unit was charged by subcooling to specs
    Aug 2011
    Yes i removed flow rater.
    Apr 2003
    Columbus Ohio
    sounds like you got a bad evap coil form the factory and its restricted
    get your post up and get your pro membership and post this on the pro side
    May 2009
    Jacksonville FL
    You need to know subcool and superheat. Your subcool should be higher than 3. Sounds undercharged. What was the superheat?
    Aug 2008
    S. Grand Prairie
    Quote Originally Posted by wsykes View Post
    Ditto
    Originally Posted by ladyfire3374:
    "I used to wake up excited about the challenges of the day. Now the anticipation level is somewhere between a root canal and a colonoscopy."
    Tennessee
    Orifice clogged from install?
    Vancouver, U.S.A.
    Any filter dryers that could be pluged?
    Air conditioning to all and to all a good night
    Sep 2010
    Western, MO
    Quote Originally Posted by Cmstech View Post
    Negative points for
    jim
    Common sense isn't very common anymore.
    Sep 2012
    mid georgia
    only half of coil getting cold? 3 degree SC? not sure what spilt is... If its milk, you aint supposed to cry. I know that. I've heard old timers call the temp difference the "split". If thats what you're talking bout, 10 just wont do. I'm probably wrong but I'm thinking under charged.
    Chicago, IL
    get your subcooling up to 10 and see what happens.
    It sounds like you're undercharged.
    Jun 2002
    south jersey
    Quote Originally Posted by lioni hvac View Post
    Yes reuse lineset, yes purge linset, Evacuation good. I pulled blower motor wire and ran a/c All feed tubes froze. Subcooling 3, airflow good my spilt is 10
    Are you saying you ran the ac with no blower? This would sure cause all your tubes to freeze.
