Results 1 to 13 of 14
    Sep 2009
    Northeast
    Refrigeration piping
    Does anybody know of any good refrigeration piping books?
    Winston-Salem NC
    What are you looking for?
    Sizing, or just how to pipe in equipment or layouts?
    Sep 2009
    Northeast
    more on how to pipe and layouts
    Jul 2011
    Nanaimo,BC, Canada!
    Diyer???
    Jul 2000
    Treasure Coast/Florida
    Quote Originally Posted by spyder00087 View Post
    Apply for Pro membership and you'll have access to the Educational Forums. We have links to some very good piping reference material posted in there.
    http://hvac-talk.com/vbb/showthread.php?t=162733
    If you're not a Pro, you can't see that one, but it just so happens I have it on my website's front page (under construction):
    http://icemeister.net/
    SW Florida
    Piping Handbook
    Sep 2009
    Northeast
    no i am not a diyer. Im a service tech.
    Jul 2011
    Nanaimo,BC, Canada!
    My apologies! The question was a little vague, as is your profile!!! The dupont piping manual us a great resource as is the trane reciprocating refrigeration manual!!!
    Sep 2009
    Northeast
    its ok. i know. anyways. thanks. I did apply for pro membership as well. What is the correct wall to pipe in a multiple evap system with compressor /unloading with the evaporators and compressor level with each other? I read about double suction risers but that doesnt apply in this application. Thoughts?
    Jul 2011
    Nanaimo,BC, Canada!
    What is the system wic wif etc???
    Jul 2011
    Nanaimo,BC, Canada!
    If the condensing unit us at the sane level as the evaps then risers are not a concern. You would need to size the main pipe run for the total capacity of the system, and each run to the evaps for their total capacity. Keeping in mind that the branch runs from the main run to each evap is sized for that's evaps capacity, and should be of equal length to maintain balanced refrigerant flow.
    You would become concerned about risers if you have an elevation change of +15' or more. All this info in available in the dupont piping hand book or the trane manual I mentioned earlier.
    Good luck I hope this helps!!
    Sep 2009
    Northeast
    thanks for your insight
    Reply
    For refrigeration piping books you can take guidance of refrigeration experts instead of using book guidance or find out on internet ,yellow pages as well.
