    Nov 2005
    My Bryant 376cav G downflow furnace doesn't work. Here is what happened. After turned on, we did saw the flame and wheel rotated. But a few minutes later, the flame disappeared and the led flashed, then the wheel stopped. The led light indicated 3-short and 3-long flashes. But I do not know how to fix it although there are some information on the tag. So please give me a help and any suggestions are highly appreciated.
    Hu
    Apr 2004
    Maryland
    there is alot of possible causes for this. And for all of them you need a pro to look at it. Nothing you can do at this point.
    sounds like a flame sensor
    Apr 2003
    Welcome to HVAC TALK. However this site has rules against giving out technical advice to DIY'ers. I have attached a link below for your convenience.
    Here's something to think about though...
    When was the last time you had that unit cleaned and inspected?
    Now you have a problem with the unit. Fuel costs are skyrocketing.
    So why not call in a professional to repair the unit? While they are there they can clean and inspect your unit to insure a safe living environment for you and your loved ones. Not to mention, having an efficient running system could save you more than the cost of the service.
    What's your safety worth? I'm guessing more than the repair bill.
    Thanks for your understanding.
    (we can't help DIY, due to site rules )
    I'm beginning to believe this is our national anthem.
    Nov 2005
    Thanks for all above suggestions. I will ask a professinal person to look at it. Thanks again,
    Hu
