Results 1 to 10 of 10
Thread: lennox TXV
08-13-2011, 06:45 AM #1
- Mar 2011
- 11
lennox TXV
Does anyone here think it is strange that lennox only has four different TXV's.
Two for ac and two for heat pump. 1-3 & 3.5 - 5
08-13-2011, 07:49 AM #2
- Feb 2003
- garland, texas
- 540
They have adjustable ones in the catalog also if you prefer.
08-13-2011, 08:49 AM #3
been that way for years, we never had any issues with them.
08-13-2011, 10:13 AM #4
Allied is the same way. But ADP calls for 3, H4TXV01, 02, 03
08-13-2011, 09:40 PM #5
Professional Member*
- Feb 2002
- 516
I had to adjust the TXV on a new install last week. It was a XP14-036/CBX27UH-036 system. With the correct SC, the SH was in the mid 20's. Did a pump down, removed the bottom cap and opened the adjustment about 1-1/4 turns. Pulled a vacuum and restarted. SH was mid teens where it should be.
08-15-2011, 06:23 PM #6
08-15-2011, 06:52 PM #7
you do with Lennox's terrible pink txv's with the rounded cap on the bottom. If you take the cap off you lose all the gas because the adjustment takes a hex key but the hole goes through the adjustor plate and the other side is open to refrigerant. Its a terrible design and after the first time I adjusted one only to find that I hadn't adjusted it enough, I've always just replaced the valve with a proper adjustable Sporlan valve when they go out of whack.
These Are The Good Old Days
08-15-2011, 07:27 PM #8
08-15-2011, 07:33 PM #9
Worse still Lennox makes valves that look exactly the same but all that you find when you take off the cap is a spring with an operator cap on it. You can get a replacement from Lennox for less than I have ever paid for any txv and they work fine when you braze them in but for a little more money why not get a valve that you can adjust in the future if need be.
08-15-2011, 08:31 PM #10
