Results 1 to 13 of 22
    Jul 2011
    Other 3-Stage Thermostat with Evolution Furnace (only)
    My other thread is kinda getting hijacked so I thought I'd start a new one.
    Looks like I'll be getting a 355CAV Evolution furnace. I do NOT have an Evolution air conditioner. I'd prefer not to blow $ on an Evolution T-Stat if I can spend a lot less on a different brand 3-Stage T-Stat.
    Will I be missing out on anything major if I buy a <Links to direct purchase sites are not allowed> 3-stage T-Stat instead of the Evolution control? If so, what?
    Last edited by beenthere; 08-13-2011 at 06:26 AM. Reason: removed price and link to direct purchase site
    Jun 2006
    Richmond, VA
    Get the evolution control and Take control of that Great furnace.
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Jun 2006
    Richmond, VA
    The ONLY thing you lose with a non-compatible outdoor unit is diagnostics.
    What you gain is complete control over the furnace with many options for comfort/efficiency even using a non-compatible OD unit. the only requirement for having a control is the indoor unit.
    I don't know
    The Honeywell FocusPro 6000 can only control three stages of heat when used for a 2-stage heatpump with electric backup.
    Jul 2011
    So the Evolution is the only option to achieve my goal?
    Rochester NY
    "I'm buying a Mercedes Benz, but I really don't want to pay for power windows or heated seats..."
    When I got into the business I sold my girlfriend an infinity. I didn't know about communicating controls and nobody hipped me to how important it was.
    Once I learned, it became abundantly clear what a ignorant mistake not having this critical piece of equipment was, so I bought her the control. Turns a nice furnace into an amazing system.
    Ignorance is not knowing better. Stupid is knowing better. None of my subsequent clients have even been given the option not to get the control. Shame on your salesperson.
    Btw, now you can't claim ignorance. Now cheap can only = stupid.
    Jul 2011
    I'm fine with getting an Evolution controller if it will do me a lot of good, even though I don't have the Evolution AC unit.
    Can someone explain all the amazing things it can do for me even with only an Evolution furnace and a standard Bryant AC unit hooked to it?
    Thanks,
    Clocker
    Jun 2006
    Richmond, VA
    Any other thermostat = analog
    Evolution = digital
    You control all furnace functions from the controller
    Jul 2011
    That means burner stage and blower speed? Anything else I could or would want to be able to control?
    Thanks!!
    Jul 2011
    I've been looking at other 3-stage thermostats, I have not found one that does fan speed yet. That seems to be a differentiating factor of the Evolution.
    What are the diagnostics that are available with the Evolution?
    Thanks!!
    Virginia
    the evolution will also due humidity control by slowing the blower and if you add a humidifier it will control that also
    Metro Atlanta, GA
    On the 355CAV furnace control board there is no "W3" terminal to hook up a 3rd stage from the thermostat. You can get the 3 stage operation from either the Evolution controller or from a single stage thermostat (with the correct dipswitch settings). You can use a 2 stage stat to get either low-high or medium-high staging. If you're going to spend the money on a 95% AFUE, 3 stage furnace I'd suggest getting the thermostat that makes it work best.
    Jul 2011
    Thank you for that powerful bit of information!
