Page 3 of 3 FirstFirst 123
Results 27 to 34 of 34
  1. #27
    Keokuk, IA
    Quote Originally Posted by wright05 View Post
    I already plan to move out and have a new place I'll be moving into in September. In Michigan our rates are .07 for the first 600 kwh and .14 for every additional above 600kwh. Our usage was for 30 days between June 18 - July 19 and at that point it was just starting to get real hot in July and that was $220. Our upcoming bill will be representing when we had over 90 degree temps for over a week with 60-70 dewpoint... it was like the tropics! I even think for the cooling quality that we get it shouldn't even be $150 - This whole summer so far it works all day and all night to keep it around 80 and if it's over 90 out then I usually expect temps around 83... I agree that there is definitely an issue with the efficiency of the unit - the heat load from the 3rd floor (keeping in mind the 1st floor is a garden style and half undergound) can't be why it's performing so inefficiently.
    That's not so bad. Down here it was mid to upper 90's for almost 2 weeks and dewpoint in mid to upper 70's, even over 80 a couple days. Your weather would have been downright cool in comparison.... and we aren't even in Kansas, texas or the South where it was really, really hot.
    But yes, that's a big electric bill for MI and with your rates. For that size home, it's possible to be under 800 kw-hr's.... or around $70-80 with your rates.
  2. #28
    Keokuk, IA
    Just a WAG (wild a** guess) but I'd say that the blower might have failed or been dirty and failing. The building mintenance guys replaced the blower motor themselves and somehow wired it up wrong (matching wire colors or reading a basic cut sheet... is so, so hard) or worse somewhow mounted it backwards (is that even possible?) ... which then made your problem worse.
    I'm really suprised you didn't have a frozen coil and/or killed the compressor. The compressor was probably cycling on and off the pressure switch.
  3. #29
    Aug 2011
    It would have been... but I've lived in MI all my life and it's not suppose to be like that way up here! lol. I absolutely agree that that would be an acceptable range IF THE A/C WAS WORKING EFFICIENTLY! It has been really miserable... and the bills are a bit "extravagant" to say the least... Our electric from September last year til now was never over 300 kwh and usually was below 250 kwh - usually around $36 a month.
  4. #30
    Nov 2000
    Eastern PA
    That RoBoTeq dude is wanted in ARP.
    Of course RoBo is wanted in ARP. Everybody loves RoBo
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
  5. #31
    Nov 2000
    Eastern PA
    Quote Originally Posted by Twilly View Post
    Twilly would like a split
    This isn't one of your porn sites!
  6. #32
    Nov 2000
    Eastern PA
    You could fight for the difference in your utility bills, but more then likely, even if you won, they would get you back somehow on your security deposit.
  7. #33
    Virginia
    Probably replaced a cylindrical object rated in micro farads
  8. #34
    Toledo, Ohio
    Quote Originally Posted by catmanacman View Post
    Twilly says T87 fermosotat?
    No Heat No Cool You need Action Fast
