Results 14 to 26 of 60
    Aug 2011
    Maryland
    Quote Originally Posted by MM#7 View Post
    to get the 10 year warranty you have to register on line w/in 60 days i think!
    WOW didn't know! The contractor didn't leave me any paperwork, any directions, or anything. I got the serial numbers myself. I'll do that immediately!!!!!!!!!!! THANK YOU
    Aug 2011
    Hmm
    Quote Originally Posted by wirelesstim View Post
    no problem, the bill is in the mail!!!!!!!!
    Aug 2011
    Maryland
    why is it dripping water for 3 months? after one day some one shoould of checked it! where is the water coming from?
    contractor hasn't been out in month and half. the first month and a half, I had a service call about 6/7 times. each time the contractor attempted to fix the water and it would work for a day then water again. he says it's either drip pan is installed wrong, or is slanted wrong, or condensation drain line isn't level, or something keeps clogging the drain line, or evap coil keeps freezing up and drain line is too small to handle massive thawing, or.... each time it's always something different.
    Aug 2011
    Maryland
    should've hired you instead of these clowns! they give small companies a bad name.
    Nov 2000
    Eastern PA
    i was typing this, i just went to Goodman Warranty site again. Not only does my name not show up under the warranty, but the warranty end date says 2016. I just bought this system in may 2011. I purchased the system with a 10year warranty in mind, meaning the warranty date should say 2021, correct?
    I see you are in Maryland. I may know the contractor and may be able to arbitrate if you'd like. My email address is in my profile.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Jul 2002
    Yuma, AZ
    • The air volume and noise can be reduced by chosing a lower fan speed.
    • The water is from humidity removed from the air. The water is supposed to go down the drain piping. (PICTURES of the drain piping would help.)
    • Was the installation permitted and inspected?
    • A complaint filed with the Maryland Home Improvement Commission is a good step now. http://www.dllr.state.md.us/license/mhic/
    "I have never let my schooling interfere with my education."
    Mark Twain
    More at: http://www.quotationspage.com/subjects/education/
    Nov 2000
    Eastern PA
    Quote Originally Posted by lynn comstock View Post
    Having had to deal with MD's HVAC inspectors in the past, I would much rather see you resolve the issues with the contractor. Then again, I would accept nothing less then a 2.5 ton cooling system with a 45k Btu furnace with the air volume set for no more then 1,000 cfm of air for the cooling.
    Direct the contractor to this site or have the contractor contact one of us via email in our profiles. There is a very good chance that the contractor can get you happy while learning a bit of an expensive lesson.
    Keokuk, IA
    A 90k BTU furnace needs about 1300CFM for a 60F temp rise. So yes, you may have an issue if hte ductwork was originally designed for a 2.5 ton AC (1000CFM).
    It can probably push nearly 1300 throguh the ductowkr, but it will be noisy with high static pressure.
    You should have had a 2.5 ton outdoor unit installed with a 50k or 60k BTU furnace... or possibly even a 40-45k BTU furance since you went from a 80% furnace to a 95% unit.
    the larger AC and furnace will make any temperature imbalances in the home worse, not better as many people would naturally believe.
    Nov 2000
    Eastern PA
    The new furnace is an 80% furnace.
    Removed pricing... had a report that non * members were giving advice.
    Conversation is not giving advice, step by step instructions are AOP * Rule limited as well as our DIY rules. Please watch how far you take conversation.
    thx
    Aug 2011
    Maryland
    Quote Originally Posted by Dad View Post
    thx
    ...sorry about that. I think quoted the price of my installation and i shouldn't have.
    Aug 2011
    Maryland
    when i get home today, i'll take better pictures. here are two videos from my camera phone that I took about a month ago. Things were half as bad then. I'll shoot some better shots this evening.
    http://allwetgoodman.blogspot.com/20...era-phone.html
    Aug 2011
    Hmm
    just curious how many bids did you get on this R/R and was he the lowest? just wondering?
