Results 1 to 10 of 10
    Nov 2005
    I have a Rudd system. The problem is the draft inducer turns on, the pilot lights the burners, the furnace fan turns on and runs for 8 minutes. The furnace and burner turn off but the draft inducer stays on. The burner relights, the furnace turns on and runs agian for 8 minutes. The system will do this several times until the temperture in the house goes up 2 degrees higher than the thermestat. Then it will finally shut down everything and stay off until the house cools down to about 2 degrees lower than the thermestat is set at. The system use to run continuesly until it eached the set temperture. What could be wrong?
    Chicago, IL
    check your filter and make sure its clean. also check that all of your vents are open. if both of those thing are ok, its time to call for service.
    Sep 2001
    Vancouver Canada
    Definetly a problem there somewhere, need a tech to check it out.
    "Go big or Go Home"
    Feb 2002
    Toledo,OH
    Sounds like its cycling on the limit. Filter clean or do you have a round Honeywell thermostat?
    Sep 2001
    Vancouver Canada
    If it is cycling on high limit then the main blower would remain on as well as the inducer.
    "Go big or Go Home"
    Apr 2004
    Is it a 90+? Could be a slow drain or a sag in the vent pipe. I'm betting on some sort of pressure switch issue.
    Post Model number.
    Nov 2005
    BAKERSFIELD CA.
    COULD ALSO BE A CBOARD PROBLEM I JUST WORKED ON A RHEEM THAT DID THE SAME THING KINDA ..IT TURNED OUY TO BE A BAD BOARD EITHER WAY YOUR STIL GONNA NEED A REAL MECH TO COME OUT TO WAVE HIS MAGICAL SCREW DRIVER OVER THE UNIT AND TELL YOU FIRST HANDW HAT THE REAL PROBLEM IS P.S POST THE FINAL OUT COME I WOULD BE INTERESTED TO FIND OUT THE REAL PROBLEM
    Jul 2005
    Wow! now thats a fantastic reply and from a pro member too. Hopefully, retired from the work force.
    Give us a break
    Jun 2001
    Louisville, KY
    Frown
    dj, after reading some of your replies, you might not want to be throwing rocks. That's a pretty empty glass house in which you reside. Take it easy and learn a little without bashing our members.
    Jul 2005
    No glass house here, Dude. and some pros need some (as you wrongly call it)....
    'Bashing'.
