Results 1 to 7 of 7
Thread: Carrier condenser info
08-11-2011, 04:36 PM #1
Does anyone have website info where I can get data, such as sub-cooling, & superheat requirements and where to measure the temps on a Carrier 38-AH-104---601?
08-11-2011, 06:22 PM #2
You may have to do some looking!
captian123-If you go into the educational forums (these are locked for pro's only) find the forum marked HVACR-Equipment, Components and Accessories. It has a visible drop menu, click on commercial HVAC and look through it for Carrier Commercial split system. You should be able to locate a 38AH044 through 38AH134 condensing units Installation, Start-Up, Maint. and Service Manual. It really doesn't specify any exact superheat requirement as these are designed for matching Carrier air handlers or built-up systems with multiple circuits. There is a charging chart for sub-cooling in this book and depending on the age of your machine you should have a charging chart decal on the inside of the control doors. If you have a Carrier air handler you can use the same site to locate your ahu and get your superheat from there. If this is a built up system (non-Carrier) then you have a lot of variables to contend with, such as piping arrangement equipment lay out, the number of refrigerant circuits. I have worked on 100 ton (which this is) built up systems with 8-10 steps of capacity, it gets real hairy adjusting 10 TXV's on the same coil. Does your unit have the optional suction line accumulator ? Is this equipped with electrical or suction pressure actuated unloaders. I hope I have helped you some what rather then confuse you more. They are going through and re-doing a lot of forums on HVAC-TALK so have some patience there are good people doing what they do best here. Good Luck captain123 and be safe out there.-Geo
Of all the things I have lost in my life, I miss my mind the most-GEO
08-11-2011, 10:12 PM #3
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
see if this helps
08-12-2011, 01:47 PM #4
08-12-2011, 06:15 PM #5
- Dec 2002
- 7,219
commercial.carrier.com
they used to only have newer stuff there
not sure if they've changed
11-30-2011, 07:15 AM #6
11-30-2011, 09:43 AM #7
- Dec 2002
- 7,219
spammer, apparently been dealt with.
