Results 1 to 13 of 13
    Aug 2011
    New Geothermal System - 2-stage or single?
    I'm replacing my 30-year old Geothermal system with a new one. I have four quotes, all of them telling me the house duct-work, etc. was designed well and efficient. One issue is the house is over 4,000 sq ft and the current system has only one zone, which will be fixed to two zones with the new system.
    Three of the HVAC guys tell me I should do a 2 stage system - save energy, etc. The fourth is suggesting a single stage for a few reasons: He has replaced a lot more compressors on two stage units than single stage units (even saying his mfg rep says the same thing), the zones will still have over 2,000 sq ft each, the house is brown, open to sun with a lot of windows, etc. so the system will still need to crank 100% most of the time when it's on anyway. It's also less expensive - though not by much so that's not an issue. My issue is that the guy suggesting the single stage has been helping with my current system for years - I trust him, etc. He says he's taken everything about my house into account and would suggest the single stage. That said, he's OK to install the two-stage if that's what I want.
    Thoughts from anyone in the business?
    Thanks,
    Dec 2010
    I would recommend the 2-stage with or without the zoning. It'll give you better comfort and dehumidification.
    2 stage.
    Virginia
    2 stage with the copeland 2 stage unlading scroll compressor this compressor has proved to be very reliable and efficient
    In a machine room
    2 stage compressors do not have a higher fail rate in my experience. Unless we are talking about the Bristol TS.
    If he has a large number of compressor failures, I would question his design and installation practices. Any compressor can be killed if it is starved for airflow or any number of other installation shortcuts.
    Worry is a really gross misuse of one's imagination. -- PHM
    Massachusetts
    2-stage is standard for our company. That said, if you become sold on the 1-stage, then I'd highly recommend a whole house dehumidifier be installed concurrent with the new geo unit. That'll go a long, long way toward controlling humidity. Something a 1-stage system is not noted to do as well as a 2-stage, particularly if you're in a heating dominant location.
    In a machine room
    Quote Originally Posted by skippedover View Post
    Good point.
    I forgot to mention, if in a predominately heating climate size lo stage for cooling load (given proper ductwork sizing). That way you have more capacity for heating.
    Jan 2002
    East Grand Forks, MN
    It's the only way to design a Job!
    Can't answer this question until I see your Load Calc.
    If you want professional advise then I need to see the Load-Calc!
    Portland OR
    Two stage is also usually more efficient. When your operating in low stage it's like driving a Prius to heat or cool the house. Jump into high stage and your driving a truck. I can't think of a reason to go single stage. I won't even install a single stage geo.
    Saint Joseph, MI
    Quote Originally Posted by SkyHeating View Post
    Isn't that anaology a little extreme? I rembmer reading that in heating, the Trane XL16i according to it's data sheets showed very little diffrence in heating efficiency in high vs. low stage. Of course a water source unit may be different. I would think it's more like comparing a Prius to a Toyota Corolla in term of effieciency.
    Aug 2011
    Geo single vs two stage
    Thanks to all for the replies. I'm still thinking about it, but leaning to the two stage because of the dehumidification issue (I live in Massachusetts) plus the long warranty on the compressors.
    FYI - Three of the guys quoting did the heat/load calculation and agreed the 6-ton geo system is good for my house. That's what's here currently and it's served us well, especially given it's 30 years old. They also calculated the return air and it's good as well.
    s chester county,pa
    2 stage with desuperheater and extra domestic storage tank
    Apr 2010
    Minnesota
    I vote for 2 stage.
