Results 1 to 13 of 17
    Washington
    Arrow
    For those of you that read the last post, yes we did get that heat exchanger out of the basement. The husband tried to convince his wife to paint it and turn it into some sort of ornament but she wasn't having any of that, lol. Had to get some 1" plywood and build a ramp and get 4 guys to get this thing up the steps but we did it. Am now proud to say we are done with the job and I couldn't be happier!
    Everything is a little more snug now that the beast is gone.
    I turned the existing supply drop into a sled fitting for optimum airflow. All done out of my van. Takes some extra time but I feel it is well worth it to keep the static down. All radius fittings for me.
    This water heater is the next to go. He is going to go with a Noritz tankless probably within the month, doesn't look like it should be too much trouble.
    Apr 2004
    Bartlett, IL
    What was the static on that system? Seems like even with those radius fittings static would be high, why so many turns?
    What size furnace?
    No cooling?
    Is that return enough to handle the supply?
    What up with the flexy gas line between rigid pipe?
    Not being sarcastic, just asking questions....
    Apr 2004
    Bartlett, IL
    Hold it!
    After reading your post it said, "only radius fittings for me!" what happened to the return drop??....
    Monmouth Junction-NJ-USA
    No sediment trap (drip leg) on gas line???? tsk tsk. Gas flex looks "ugly" Those air cleaners work much better with radius or at least a throat with turning vanes. Other wise nice looking changeout.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Washington
    There is a scoop in the return drop, where it comes down and where it mates to the air cleaner. As far as the flex, it can be used as a drip leg, passes code over here in Seattle. Knowing this is Seattle, that should answer your A/C question. Don't need it!
    That is an excellent looking job! Nice to see pride put into
    our trade. Lucky homeowners to have someone care about their
    work. Keep it up.
    Oct 2005
    How is that flex being used as a drip leg???
    Oct 2005
    looks good. But why isn't there a drip leg in the gas line
    Rapid City, SD
    *shrugs* around here if ya put a loop in the gas flex line it classifies as a drip leg. Not right in my mind... but they pass it.
    Washington
    You're right, there isn't a drip leg there, didn't notice it til now. Passes code around here, but that doesn't make it right. I'm gonna go back there tomorrow and put it in. To answer the "why so many turns" question; You can't see it from these pics, but this is a real old welded duct system from the 40's that is pretty time consuming to take fully apart as far as each supply drop is concerned, so I figured the best thing to do would be to at least put a sled there to help it out. Sometimes you have to improvise, you gotta admit it is much better than just slamming some straight duct up there. And for 2hot2coolme, the R/A duct is 10X24, more than enough in this application considering the floor return is almost directly above the drop.
    Washington
    You're right, there isn't a drip leg there, didn't notice it til now. Passes code around here, but that doesn't make it right. I'm gonna go back there tomorrow and put it in. To answer the "why so many turns" question; You can't see it from these pics, but this is a real old welded duct system from the 40's that is pretty time consuming to take fully apart as far as each supply drop is concerned, so I figured the best thing to do would be to at least put a sled there to help it out. Sometimes you have to improvise, you gotta admit it is much better than just slamming some straight duct up there. And for 2hot2coolme, the R/A duct is 10X24, more than enough in this application considering the floor return is almost directly above the drop. It was sized by my supervisor using Manual D by the way.
    Washington
    Oops, sent twice, don't know why I can't delete the first, it won't let me!
    Rochester, MN
    How far of run do you have on the PVC?
    Short elbow allowed??
    Other than that, look good.
    I agree about the gas line trap.
