Results 1 to 2 of 2
    Aug 2011
    Tracer Summit CPL Help
    I am looking for some guidence on a particular routine. What I need is a CPL that will look at a set amount of Space Temperature deviations from setpoint and store them in order from highest to lowest. Either that or remove the last known highest deviation.
    The purpose of this program is to release electric heat one unit/a min based off the highest deviation of space setpoint. Rinse and repeat with the previous ignored.
    Really having a hard time with this one and would greatly appreciate any help this community could offer.
    Thanks for your time
    What your specifically requesting would be pretty hard. I would think you could achieve the same result just looking at it a different way.
    I dont understand fully though what your end goal is? You want to disable electric heat based on the highest unit deviation from setpoint? Is this globally or per unit?
