Page 1 of 4 1234 LastLast
Results 1 to 13 of 51
    Nov 2001
    East Texas
    Frown 1st foam house - seem to be undersized ?
    Just started up 3 ton Rheem on open cell foam new construction. Foam on outside walls and roof rafters. Was 96 in house yesterday when I started unit, ran all night, checked at 7 am this morning, only pulled down to 83 inside.
    This is giving me a bad feeling in my stomach if you know what I mean.
    House is 2600 sq. ft. It also has been extremely hot here. 106 and 107 day after day. The design temp for this area is 97.
    Question , how should I handle the ceiling load calc when the insulation is up on the roof rafters. Now the whole attic space is being cooled .
    I may be ripping this system out and going larger.
    Aug 2011
    Confused
    Quote Originally Posted by Timber View Post
    tell the customer all the humidity you're taking out of the air!
    You could install return ducts into the living space ceiling, add insulation so you dont have the attic load to the house.
    Do you have a heatload calculation?
    Nov 2001
    East Texas
    Quote Originally Posted by air2spare View Post
    I used wrightsoft. But maybe my data entered was off for the ceiling load.
    I was thinking about insulation above the ceiling to remove or lessen the ceiling load.
    Just talked with another local contractor a they are sizing the units the same regardless of the type of insulation used. That being said this would have been a 4 ton unit.
    Air2spare when u say add returns in ceiling, you would also tie them into the return plenum at unit. Right.
    May 2009
    Earth
    Done a few foam houses, I always size the same as non foam as well.
    Nov 2001
    East Texas
    Quote Originally Posted by EugeneTheJeep View Post
    Well I think I screwed up. Makes me want to say some cuss words .....
    Aug 2011
    Confused
    hey timber, wow, where i come from, we call that a money loser!!!
    i feel for you. these days i don't do any new installs, i do repair,replacement,service, no money$ in installations, any way good luck, really, been there done that! again good luck!
    Madison, WI/Cape Coral, FL
    You have a few things to check before going off the deep end. The refrigerant change and air flow over the cooling coil are the starters. Over charge or undercharge will reduce btus moved. The coil temp should be 25^F below the return air temp. Lower coil temp improves latent removal and but slows sensible cooling. In your case, to improve the sensible cooling, you could start with -20^F coil temp.
    What is the situation on fresh air ventilation? Limit the fresh air to 70 cfm when occupied.
    Also, are all of the blinds and window covers inplace? Solar gain is a killer that can be slowed with shade, blinds, or other ways.
    More info on the temp/%RH, coil temp, and superheat/subcool. Is the outside condenser clear of obstructions and free air flow.
    Regards TB
    Nov 2001
    East Texas
    Regards TB
    I will check the charge this afternoon. This unit is coupled with 90 % furnace running on Hi for cooling. Probably not going to get anymore Sensible out of that.
    ERV is not hooked up yet.
    Aug 2011
    Hmm
    hey timber, what's the delta over the coil? got enough return coming back to the furnace? you pprobably ck'd already, but trying to give you moral support!
    Jul 2000
    NW IL.
    Yes but have you measured the TESP and plotted the air flow on the blower chart to determine that airflow is 1200 cfm for the 3 tons not 2000 cfm?
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
    If you want to call me I will discuss a few ideas about it
