Page 4 of 4 FirstFirst 1234
Results 40 to 50 of 50
Thread: TXV hot swap
  1. #40
    I have done this once with good results. In the perfect world you would have a filter-dryer already in the lineset to clear your mind.
    However, I must say, I have only seen 1 410a TXV actually fail.
  2. #41
    Jun 2009
    it you have the change the txv because it is malfunctioning possibly from debris changing the lld would be a good thing.
    damm i must be slow not sure if it could change it out with presssure remaining on both sides
    i guess if you leave enough liquid in the system and are not using a torch - i hate that- and have your buddy hold his thumbs over the exposed ends while you are in between his legs it might work.
    i probably have bad luck with these things so i'll recover and my buddy has short arms
  3. #42
    May 2009
    Quote Originally Posted by Stumbo View Post
    Only one? I see approximately 3 per week. 410a and r22. Goodman had a terrible problem with Parker txvs
  4. #43
    Quote Originally Posted by ChaseAir View Post
    I've never seen a 410a valve fail and have only seen handfull of 22 valves (on residential split systems) fail. All were 15-30 years old and all had lost the charge in the powerhead. All were working as good as new after simply installing a new powerhead
  5. #44
    May 2009
    Quote Originally Posted by craig1 View Post
    Do you work on residential heat pumps? Do you verify that they hold the specified superheat? Units in Florida make it to 15 years occasionally.
  6. #45
    Feb 2013
    north georiga
    you must not work on york/unitary products group equipment then because i see 410a txv fail more than they should
  7. #46
  8. #47
    The Hot South
    You can always tell the new users.
  9. #48
    Feb 2013
    north georiga
    its ok to make mistakes as long as i learn from them
  10. #49
    Austin, Texas
    And to think I read all 4 pages.
  11. #50
    Virginia
    I was into the 2nd page before noticing post date .... meh
    Wheres my shovel
